Welll, if you've seen the last OB thread I posted you may know that I want to build one using the alpha 15 and an fe87. They sim very nicely together in a baffle that suits me.
Thing is, once its built, which thankfully wont take long... big fan of the OB built simplicity... I'll want to tune up the fe87. Basket damping is an obvious one. Closest thing I can find to duct seal here is plumbers putty, but I'm sure its very similar and will do an equally good job. It's cheap too 750g for a couple of pounds. Puzzlecoat again is an obvious one and mod podge is available here no problem. I'll probably give Enabling them a go too. My main question is the dammar coating mod. The main info here related to the fe126/7 and it seems 9 and 17mm in a 6 sectioned ring around the driver works well - at least according to the planet10 peeps who have vastly more experience than I. This begs the question, where on the fe87 could benefit from this treatment? Thanks Edit: forgot one thing. Does anyone know if the 87 has the same dustcap removal problems as the 126/7? I imagine I may want to plug them too... |
#2 | |||
To source duct-seal, try an HVAC supplier. If not successful, then blu-tak or other poster adhesive putties that you'll likely find in a craft shop will work also. Quote:
While sharing the same basket frame and a few other dimensional characteristics, the FE87E is a considerably different driver. Actually, it would be more appropriate to say that the FF85K is exceptionally different from the standard budget Fostex FE series. Indeed, due to the UDR surround more commonly found in the "Sigma" series, and the huge motor /cone ratio, it's an orphan in the FF series, and quite a stunning little driver within it's limits, but I digress. Back to topic - there are a couple of methods for determining location of the EnABL blocks (more literally like polka-dots on a driver of this size). I'd suggest you contact Dave directly for some guidance. On drivers of these smaller dimensions, care needs be taken in terms of the type and total mass of material applied to the moving diaphram/cone. Quote:
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#3 |
Thanks chris
The plumber's putty I found maintains that it will remain "permanently flexible" and I have seen blu tack in sunlight dry out in a year so I'm not that keen to use it. I'm 99% certain that the duct seal dave uses simply isnt available here in the UK. On the plus side, since these drivers will be mounted in an OB, I'll be able to very easily see if there are any problems with the putty drying out. I probably will contact dave directly about Enabling these, but theres quite a lot of info on it around already, and tbh I expect it wont be long before he chimes in here anyway. Out of interest, your post seemed to indicate that the FF85k is flat out a better driver than the FE87. Do you believe this to be the case? My basis for choosing the FE87 was the higher Qts and the lack of rising response above 10kHz which tends to bother me. The other point I was really referring to was the dampening of cone vibration modes. This is achieve on the fe126/7 with the damar coating in 6 sections around the cone 9 and 17mm from the outside edge of the cone. I was wondering if there was wisdom as to where similar treatment should be applied to this smaller cone. Thanks |
#4 | ||||
Once treated, we've had great response to their performance in a "micro" sized enclosure, with powered woofers, XO's around 200 or so IIRC. Quote:
It should be pointed out that after receiving the first pair of FE127s treated by Bud, we did more than a few weeks of comparative listening to various combinations of EnABL alone, and this earlier treatment to reach our current conclusion - that as regards the two drivers in question (FE126/7), the two treatments are definitely synergetic. To the best of my limited knowledge, there has been no published "wisdom*" on this subject regarding the smaller Fostex drivers in question. *totally non sequitur, but every time I encounter that word, I flash back to the halcyon days of my twenty-something, and the timeless brilliance of FZ: Information is not knowledge Knowledge is not wisdom Wisdom is not truth Truth is not beauty Beauty is not love Love is not music Music is THE BEST... Wisdom is the domain of the Wis (which is extinct). can you image the fun he'd have had during the past 8yrs? oh, yes the hounz did enhale
#5 |
Dave actually attributes the exact position of the damar mod to MarkMcK (http://fullrangedriver.com/forum/viewtopic.php?id=535) though it is long before my time I have no doubt you guys came up with the damar treatment first and Mark's comments just helped to fine tune it. I'd be interested in how those figures of 9 and 17mm were reached - I should read that thread Dave references.
Failing finding any scientific basis for how they were derived or if it is beyond my scope to do the calculations I will likely just downsize the 126/127 positions for the smaller driver. Can't imagine it would do much harm and I quite like the look too! |
#6 |
frugal-phile(tm)
The damar mod was our attempt to quell the resonances that Mark found... he never did divulge how he fived them.
Since no resonance studies have been done on the smaller drivers, we wouldn't know where to work so best to do nothing. Light puzzlecoat on the cone, and EnABL. The newest non-whizzer cone drivers don't seem to benefit much if any vrs an EnaBLed dome -- after 40 years of plugging away art the same basic cone/dome Fostex dramatically revised the e series. The older Fostexes do benefit. Phase plugs for the latest FE83/97/103/107.126/127 are mainly appropriate to replace poked in dust-caps (althou it seems it might be worth playing with a concave dome if yours do get finger-poked. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
I have Martins OBs with the FE87. very good performance considering the simplicity. Took some dinking with position in the room but will get down to the low 50s if positioned correctly.
All i can state is they do what i want. Try some insulation pipe wrap or a water snake with a slit around the edges, this lowers the recieved edge diffraction greatly. ron |
#8 | |
http://www.geocel.co.uk/dynpdfs/250.pdf : looks like duct seal to me |
#9 |
Thanks all. I have the benefit of using my computer as the only source so I can actually "fix" a lot of speakers quite easily by using th iTunes EQ. Much as I think iTunes is a terrible piece of software (for windows anyway), the interface is great and surprisingly the EQ is very good. Most other software I've tried immediately introduces horrible distortion when you try to use the equaliser, but iTunes does very well. I'm sure with the EQ I can have them playing well into the 40s without issue.
I'm glad in a way that I dont have to remove the dust caps. Saves my drivers their greatest risk... I'm still uncertain about the damar to control the cone resonances... as I said, I like the look, and you apply it in fairly thick swathes so I might be tempted to "guess" at where they should go and give it a try hoping the swathes will get the key areas. I have my doubts about how much the pipe around the edges trick would actually help with diffraction. To my knowledge much greater rounding is required to have a significant impact on edge diffraction, but in fairness, you've tried it and I haven't so I certainly won't rule out what you say. The point is moot anyway as aesthetics pretty much put it out of the question... I dont really want that around the edge of my speakers. They will see my roundover bit though, but thats really just an aesthetic thing again. It does bring an idea to mind though... I wont be trying it as the baffle is only an inch wider than the 15" driver I'm using, but a pair of OBs using several sheets of flexi-ply stuck together on a gently curving frame could work quite nicely. I'd be surprised if someone hasnt done it before though.. |
#10 |
Its not the radius of the material, its the sound absorbation of the diffracted energy from the sharp edges. ron |
| fostex fe87 blh? | mctavish | Full Range | 3 | 16th April 2009 09:47 PM |
| fostex recomended box fe87 | jonastus | Full Range | 10 | 17th December 2006 08:28 AM |
| ns-10 mods | nvinyl66 | Pass Labs | 42 | 17th February 2006 01:21 PM |
| What diy class a amp to use for fostex fe87 in Buschhorn | ovy | Solid State | 0 | 10th July 2004 05:13 AM |
| Class a amplifier for fostex fe87 | ovy | Solid State | 0 | 7th July 2004 05:32 AM |
| Page generated in 0.14490 seconds (86.09% PHP - 13.91% MySQL) with 11 queries |
