Hemp Acoustics FR8C in Angular Spiral Enclosure
Old 4th November 2008, 05:11 AM   #41
ttan98 is offline ttan98  Australia
They belong to a friend of mine. He said I can try if I like them I can buy.
this pair has a rising response around 8khz, I would not use it as a full ranger. I tried to use them as a 2-way x-over around 3.5khz, sounds very good. Hempcone material has an attractive sound. Efficiency around 96db.
Old 4th November 2008, 09:36 AM   #42
Ipanema is offline Ipanema  Malaysia
Ipanema's Avatar
Big waste to cross it at this low. have you try with notch at 8khz?
Old 4th November 2008, 11:10 AM   #43
why should I notch it if the spec tells you there is no rise. If you want tp purchase them you can notch it. you really need a measuring device to measure the precise freq in which the rise occurs. your units may be different from mine.
cheers.
Old 6th November 2008, 04:46 AM   #44
cjctan is offline cjctan  Singapore
Hi ttan98,
Which seller allow you the pair for trial?
Hi cjctan,
Since you're not quite happy with Fr8C, can you sell it to me with a good discount. Just want to try out how it sound.
Regards.
Hi Ipanema,
I have no intention of selling it at a "good discount" but will consider swapping with a pair of fostex or other fullranger
Old 7th November 2008, 12:46 AM   #45
Ipanema's Avatar
Hi Tan,
Pls PM me.
Thanks.
Old 2nd June 2009, 04:32 PM   #46
Telstar is offline Telstar  Italy
Originally posted by panomaniac
The Hemp FR8c isn't as bright or shouty as some FR drivers, really.
I dont have experience with many FR, but I do find my FR8C shouty. Way too much. To the point that I either use a notch filter (or two) or replace them.
To their advantage, I can say that the HF (probably over 10k, havent measured yet) do not beam and are quite pleasant.
I'm not sure what to do ATM. My drivers have about 130hrs, so the burn-in is done.
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Hemp Acoustics FR8C in Angular Spiral EnclosureHide this!Advertise here!
Hemp FR8C Enclosure Suggestions Hardman Full Range 112 1st February 2014 03:24 PM
Hemp FR8C in Fonken cabinets xecluded Full Range 7 9th August 2009 06:22 AM
Help with Angular Spiral yan6 Full Range 19 10th February 2009 11:31 AM
Enclosure for a Hemp FR8C G Full Range 17 20th January 2008 04:24 AM
Bass Reflex design wit the new Hemp Acoustics FR8C driver audio_moksha Multi-Way 4 7th March 2007 08:30 PM
