Old 28th July 2008, 09:47 PM   #1
cgrums is offline cgrums  United States
Default Fonken Materials
Howdy All,
I was shopping this weekend for parts/tools in preparation of building my first pair of speakers, the Fonkens. I got a screaming deal on several pieces of 3/4" BB ply but understand that the design calls for 1/2" material (excluding the baffle). I've searched through a number of threads but have yet to find out how big a problem the extra 1/4" is going to be. Do I need to go get 1/2" sheet or am I good to go with the 3/4"? Thanks very much for the advice.
~Charlie
Old 29th July 2008, 12:21 AM   #2
DaveCan is offline DaveCan  Canada
DaveCan's Avatar
I would reason that as long as you can keep all the internal measurements that the driver is loaded in, to exact spec, then it shouldn't matter how thick your ply is, except if it was real thin etc.... Dave
Old 1st August 2008, 06:02 AM   #3
chrisb is offline chrisb  Canada
That's pretty much right Dave; "stretch" the panel sizes to allow for the extra 6mm / 1/4" per layer of material - except for the dimensions related to volume of the port slots. In other words keep the dividers at 9.5mm (3/8") and retain the height and depth as per plans.
The additional thickness is more than enough to change the resonance characteristics of the box, so it could well be worth the effort to attach the rear panel removable via cleats, allowing for adjusting of damping. It's certainly possible to overdamp an enclosure this small - and once it's fully assembled, internal access it very difficult (unless you're a dental surgeon)
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
V8 Fonken design ? Bigun Full Range 30 28th January 2009 08:58 PM
fonken floostander MK... Gomoo Full Range 2 22nd January 2009 12:32 PM
The first Wall Fonken?? JeremyB Full Range 14 19th January 2009 01:13 AM
Fonken black ecir38 Full Range 2 17th December 2008 06:45 PM
Fonken-- my 4th build Jim Shearer Full Range 47 13th September 2008 06:23 AM
Page generated in 0.06681 seconds (71.72% PHP - 28.28% MySQL) with 10 queries
