Old 13th July 2008, 11:14 AM   #1
widowmaker's Avatar
Send a message via ICQ to widowmaker
Default BL Horn Project Helix-5000
This is my last project of Exponential BL Horn.
I tried to design sufficiently big construction,
but (almost) suitable to set up in normal room.
(what do you think about title "family scandal")
Some parameters:
Lenght of exponent is 5000 mm (34.4Hz for 1/2 wave lenght).
Throat area is 88 sq. cm.
Offset ratio is approx. 0.5
Mouth area is 0.45 sq. m.
Volume of chamber is 7 liters, but it is easy to reduce to 3.5-4 liters (tighter bass and smaller drive excursion).
Helix is suitable for Bulgarian Full Range Drivers - Ether 5/6, but fits also Fostex 206/7 and others.
Audio Researcher
Daniel Petrov also known as widowmaker
Old 13th July 2008, 11:59 PM   #2
Very ambitious, beautiful folding ...
Where to get the Ethers ?
Cheers
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 14th July 2008, 07:37 AM   #3
what about mounting the driver with offset onto
the front baffle / into the pressure chamber ?
Looks possible without changing the folding, would bet
it will sound better then.
Yes i know, some people don't like to look at drivers mounted
offset. But others are interested in best sound mainly ...
Cheers
www.dipol-audio.de
Old 14th July 2008, 02:45 PM   #4
widowmaker's Avatar
Cheers
You can get Ethers from Asparuh Jeliazkov, designer of these drivers.
Phone number for contacts:
00359882203760, Kiril Kirilov (Asparuh doesn't speak english)
About driver offset...
Below I attached PDF with offset ratio 1.
Audio Researcher
Old 14th July 2008, 02:51 PM   #5
Was it a joke, because you don't like side offset ?
Or do you mean everyone is free to introduce an offset
if he likes ?
I cannot see any difference between the drawings.
But filenames differ. Maybe i am getting blind ...
Sorry ...
www.dipol-audio.de
Old 14th July 2008, 03:00 PM   #6
gychang is offline gychang  United States
anyone know of anyone that built in?, live picture somewhere?
gychang
Old 14th July 2008, 03:06 PM   #7
widowmaker's Avatar
Take a look more carefully
left view is with offset 1, right with 0.5
Audio Researcher
Old 14th July 2008, 03:11 PM   #8
widowmaker's Avatar
This way is easier than changing the position of driver's hole onto front panel.
See also:
Audio Researcher
Old 14th July 2008, 04:02 PM   #9
REC1 is offline REC1  United States
During my investigation into wave forming from the filter chamber to the throat a "funnel" approach always produced the better result. It may be nothing more than a slug of pressure at that point but it will affect the later wave form.
ron
Old 14th July 2008, 09:03 PM   #10
OK i see ...
what i meant is more like this ...
the drawing is maybe somewhat exagerated, just to show
what i mean.
www.dipol-audio.de
Looking for circuit diagram from Helix JoergST Car Audio 1 16th November 2010 02:22 PM
Brax, Helix Schematic senee Car Audio 2 1st February 2008 05:42 PM
Helix repairs? thxdave Car Audio 0 10th February 2007 08:40 PM
Helix - hows your project going along? thylantyr Solid State 0 17th August 2002 04:55 PM
Hey Helix... I have one question about Crescendo? Eccu Solid State 29 22nd July 2002 05:18 AM
Page generated in 0.10305 seconds (80.52% PHP - 19.48% MySQL) with 11 queries
