Old 9th July 2008, 01:51 PM   #1
smithie is offline smithie  United Kingdom
Default jx92s and horn enclosures
hi
i really love the look of this kit,im just wondering if anyone has any more low down on it...ie how good is it,specs,sound quality etc...has anyone built them...just cant find nothing else on them.
would be tempted to suck it and see,but the manual to it on the site is vague,hard to make sense of and it would be alot of work if it sucks!!!
any help guys
all the best
smithie
Old 9th July 2008, 02:05 PM   #2
Scottmoose's Avatar
What kit?
Old 9th July 2008, 02:08 PM   #3
its just one of those days...sorry about that.
and without further adue..heres the kit...i hope!
http://www.hifisound.de/oxid/oxid.ph...N-SPEAKER-KIT/
all the best
smithie
Old 9th July 2008, 02:18 PM   #4
Scottmoose's Avatar
Well, it looks acceptable enough on a graph. Interesting folding scheme. As for the sound, only one way to find out I'm afraid. Strikes me it might be a little over-involved for what it is, but YMMV as always.
Old 9th July 2008, 02:32 PM   #5
hi
thanks for your input.
thats the trouble,hate to go to the effort of building it and it isnt anything special
just fancied trying a horn design thats not to big, with this driver!
smithie
Old 9th July 2008, 03:25 PM   #6
REC1 is offline REC1  United States
With the higher Qts you should be able to get away with a lot.
I can find no reference to folding? As with any comprimised BLH the mouth will only support the actual horn action,the lowest frequencies would still be a TL action.
Iffin it were me the Jordan FR,Qts and greater Xmax would not require a BLH. GM has an excellent design for a MLTL that would work well and be physically smaller.
ron
Old 9th July 2008, 03:58 PM   #7
Scottmoose's Avatar
That would be my choice too Ron. The JX92S wouldn't be my choice for a BLH, but to each their own I suppose.
Re the folding, there's a small (and easy to miss link) at the bottom of the page to a pdf file which has the folding on it on the third page. http://www.hifisound.de/oxid/out/oxb...JJ-3001816.pdf
Old 9th July 2008, 04:27 PM   #8
GM is offline GM  United States
GM's Avatar
Greets!
Can't comment on how it will sound to you in your room, but compare Zaph's measured response (click the JX92S link) to the horn's to get a clue how much it messes with its response all the way up due to phasing and acoustic mass loading issues........
Bottom line, TJ doesn't recommend horn loading and IMO if a BLH is used it should be a large, very low compression one such as Nelson Pass chose and damp it down as required if too 'boomy' in-room.
As always though, YMMV.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th July 2008, 05:28 PM   #9
from teds site...
Q: Can I horn load the JX92S?
A: Yes. This has been done with excellent results.
thanks for all the replies...general census seems to be it isnt up to much or worth the effort...i was just curious really,just fancied hearing a horn on the end of my 845se amps.
confused over people saying horns hnot suitable for the jx92s when the man himself seems to be saying otherwise!
all the best
smithie
Old 9th July 2008, 06:41 PM   #10
Scottmoose's Avatar
Not really. He's not recommending it. He's saying that you can do it, with decent results (if you go with a large low compression design like the J-Lo as GM said), but that doesn't alter the fact that it's not what the drivers are designed for.
Jordan JX92S full range drivers in stainless steel enclosures JohnnyBoy Swap Meet 19 2nd May 2006 04:40 AM
Choosing Woofers for Horn Enclosures asauer Multi-Way 8 23rd January 2004 05:57 AM
Jordan JX92S horn BrianGT Multi-Way 4 4th January 2003 05:39 PM
Page generated in 0.09713 seconds (77.01% PHP - 22.99% MySQL) with 10 queries
