Old 1st July 2008, 02:12 AM   #1
Salsero is offline Salsero  United States
Default bipole speaker + tweeter
Is there any merit to incorporating a tweeter into a 4" full range bipole speaker? The motivation for the question is the following: I notice that many of the full range drivers have a lot of peak and valleys on the db vs frequency curve beyond 10kHz. A separate tweeter crossed over beyond 8kHz may smooth out the highs while allowing a very wide range for the full range drivers. Assume we use a pair creative sound FS125 or one of the many TB drivers available for the full range drivers. How would one design the cross over for the tweeter - full range pair?
Thanks in advance
Salsero
Old 2nd July 2008, 11:42 PM   #2
i made a bipolar speaker using FR125 S some weeks ago.
I decided not to use a tweeter or supertweeter, i would fear
the loss of the most important advantage of the concept:
Homogeneity.
When building 2 way, i would suggest to use 2 tweeters and
build a classic 2 way crossover with XO at say 2.1 .. 2.3 Khz,
of cause then it is not necessary to use fullrangers anymore.
Since a bipolar speaker tries to simulate an omnidirectional
sound source, the tweeters could be mounted back to back
as near as possible (neodymium tweeters) on a separate little
baffle ontop of the fullrangers
(as near as possible to the fullrangers vertically).
Delay of the tweeters could become a problem with such a
concept, if the enclosure is too deep ...
Top of the enclosure has to be designed to avoid protruding
edges near the tweeters.
Maybe a front firing supertweeter is an option, but i do not
believe there is much to gain ... but maybe it is a matter of
taste. For a supertweeter i would suggest a 1. Order XO.
Voice coil inductivity of the Fullranger should be compensated,
to ensure, that the lowpass for the fullranger works properly.
Cheers
Oliver, RFZ believer (?)
www.dipol-audio.de
Internal wiring for a bipole surround speaker? hifisponge Multi-Way 1 16th August 2007 07:04 AM
bipole speaker selection advice Salsero Full Range 7 16th April 2007 09:28 PM
t-amp with fostex 127e bipole or FR125 bipole? alexg Full Range 6 23rd August 2006 07:49 AM
Which tweeter DIY amp for active speaker ?? Henrik Juhl Solid State 8 9th November 2004 04:42 PM
Dipole / Bipole rear effects speaker NicolasGaal Multi-Way 1 4th January 2004 09:16 AM
Page generated in 0.07189 seconds (70.26% PHP - 29.74% MySQL) with 10 queries
