TB 2" Full Ranges
TB 2" Full Ranges
Old 22nd June 2008, 05:14 AM   #1
MiniVanMan is offline MiniVanMan  United States
Send a message via MSN to MiniVanMan
Default TB 2" Full Ranges
Hey guys, I've been looking at a couple of the TB 2" widebanders for an upcoming project, and have a question about their advertised sensitivities.
http://www.partsexpress.com/pe/showd...number=264-805
http://www.partsexpress.com/pe/showd...number=264-808
Sensitivity in the 85-86 range seems a little high for such a small driver. On the flip side, they are fairly useless under about 500 hz, even though they boast an Fs around 150 hz, so it's possible that 85-86 db is realistic above 500 hz.
So, has anybody used either of these drivers, and can give a good sensitivity number, or should I trust Tang Band, which is rather notorious for inaccurate specs?
If not, I'll buy a couple and test them myself, but I'd like to save the $30.00 if possible if they're grossly overrated.
Old 22nd June 2008, 05:44 AM   #2
ArjenShenzhen is offline ArjenShenzhen  China
Send a message via MSN to ArjenShenzhen
Hi there Mr Minivanman.
I think they look okay but a PP cone might be bit heavy for such a small speaker.
I have some 3" drivers laying about sound allright, but up to 15 K not all the way up.
Ive seen some other small 2" speakers before and have some here at home that sound quite nice, but any Bass response will be hard.
Always check the power supply... and my spelling...
Old 22nd June 2008, 08:51 AM   #3
Oh, they're going to be used as dedicated midranges in a 3-way tower. I haven't worked out the crossover, but I could go as high as 1khz for a high pass. I'll also be using a tweeter from about 10khz up, so I'm not asking a whole lot from them.
What I'm actually looking for is a good performing, but not costly 2-3" driver that will do 500 hz up to about 10k. I'll probably cross lower for better off-axis response, but I haven't figured it all out yet. I would like a sensitivity per driver of 85-86 db, or even higher is possible. A dome is not feasible for this application.
Old 22nd June 2008, 09:23 AM   #4
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
TB 2" Full Ranges
How about these?
http://www.swanspeaker.com/product/htm/view.asp?id=121
They also a gold coloured 2 inch and 3 inch.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 22nd June 2008, 02:50 PM   #5
Originally posted by richie00boy
How about these?
Sensitivity is way too low on the HiVi offerings. I understand bass response is better, but I'm not looking for that. I also need 4 ohm drivers, as I'll be running 2 of them in series per speaker, and I need a final 8 ohm load. At least that is what I would prefer.
The overall design is going to be a WWMTMWW setup using Dayton RS125s for the low end. Since combined, the Daytons will have a sensitivity of around 89 db, I'd like two small midranges that will sum to around 89 as well. They need to be small for several reasons that I won't go into.
Old 22nd June 2008, 02:56 PM   #6
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
The T/S-data and published FR plot seems IMO to be quite consistent.
b
1(1)
Old 22nd June 2008, 03:29 PM   #7
b
1(1)
Great, thanks.
I just ordered a couple off 852s off of ebay. Found them for for $23.00 shipped for the pair, so I won't be out much if they don't work out.
Again, thanks.
TB 2" Full RangesHide this!Advertise here!
What full-ranges offer most midbass punch? CZ Eddie Multi-Way 21 19th August 2008 02:55 AM
Samco Full-Ranges mod_evil Full Range 2 24th March 2008 04:26 PM
FS: 1 pair Fostex FE-166ES-R full ranges zobsky Swap Meet 6 13th April 2007 06:57 PM
What should I do with these Philips Full Ranges? miccomacho Full Range 6 14th February 2007 04:25 PM
Full Ranges for Rock/Metal juan_caliente Full Range 17 25th June 2005 07:09 AM
