desktop TL with 3" driver (with real bass) - Page 6 - diyAudio
Old 16th January 2013, 06:46 AM   #51
xrk971 is offline xrk971  United States
xrk971's Avatar
Chaz,
That's really low for a 3 in driver - can you post FR sweep plot?
Old 16th January 2013, 04:07 PM   #52
I'll try to, but it won't be coming anytime soon. I'm heading out of the country in a couple of weeks and it won't happen until I get back. However, in the meantime I could run a sweep and record it, just to provide evidence of the bass extension. Obviously it will sound like crap.
Then again, what do I know?
Old 16th January 2013, 11:56 PM   #53
Yikes, sorry for the faulty info guys. I THOUGHT that was too good to be true, especially since it contradicted the simulation. I didn't realize my subwoofer was hooked up last night. The actual bass extension is a more moderate ~55hz.
Old 23rd January 2013, 03:22 PM   #54
dzwer is offline dzwer  Bulgaria
dzwer's Avatar
Default Help with 4" coaxial car driver
Can someone rework the project for these speakers?
TS-E1076 (Archived) - Pioneer UK
Here are some measured parameters from this Russian website:
avtozvuk.com
Nominal power: 25W
Frequency response at level -3dB: 110 - 22000Hz
Sensitivity dB/W/m: 88dB (150 - 15000Hz)
THD at level 90dB at 1m(160 - 4000Hz): 2,03%
THD at level 90dB at 1m(100 - 125Hz): 9,15%
Midbass resonance frequency: 113Hz
Qts: 0,657
Vas: 1,94l
Force factor(BL): 3,4 T-m
Mms: 3,9g
Zmin for the midbass: 3,5ohms
Old 23rd January 2013, 09:06 PM   #55
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
try and find (or estimate) the driver's Sd, and then use the spreadsheet found in this thread: TL alignment tables in excel to get a good idea of how a TL should look. with a high Qt driver, you can choose a lower than fs tuning of the TL
Old 24th January 2013, 02:30 PM   #56
dzwer's Avatar
Sd is 78.54 sq.cm(R=5cm) and nothing happened, when I fill in the xls file all required fields.
Does it mean this driver is not suitable for TL?
Old 25th January 2013, 10:07 PM   #57
Henkjan's Avatar
what do you mean "nothing happened"? did you allow the macro's to run?
the driver is suited for a TL
Old 26th January 2013, 11:02 AM   #58
dzwer's Avatar
I've forgot the macros...
Thanks!
Now the drivers are given for T/S measurements.
Let's see if the results will differ from the Russian website.
Old 30th January 2013, 02:38 PM   #59
dzwer's Avatar
Here are the measurements:
Driver: Pioneer TS-E1067_1
Compliance (Vas) 1.065 liters
Resonance (Fs) 131.515 Hz
Mechanical Q (Qms) 5.990
Electrical Q (Qes) 1.089
Total Q (Qts) 0.922
DC Resistance (Re) 3.187 Ohms
Piston Area (SD**2) 50.000 sq cm
Driver: Pioneer TS-E1067_2
Compliance (Vas) 1.055 liters
Resonance (Fs) 131.512 Hz
Mechanical Q (Qms) 6.000
Electrical Q (Qes) 1.087
Total Q (Qts) 0.920
DC Resistance (Re) 3.198 Ohms
Far away from the listed above...
I'll think what to do with these drivers...
Old 4th July 2014, 07:54 AM   #60
Originally Posted by Bjohannesen View Post
Hi
The folded version of TABAQ has very good bass performance with the 3" TB.
http://www.coolcat.dk/bjoern/TABAQ%2...et%20build.pdf
PS: You can mount the driver in the middle of the baffle it you like.
Hi from
Bjorn
This is almost exactly what I'm looking for right now! Which drivers are those?
Which driver is the "real" Fe103a?? Sylver300B Full Range 108 11th April 2011 12:36 PM
FS: Snell 6.5" - 7" mid-bass driver woofer feke67 Swap Meet 0 31st December 2007 07:11 PM
looking for a small 2" or 3" driver with poor bass response space-cake Full Range 3 27th December 2007 01:16 AM
"Real Life" Bass recordings gmikol Subwoofers 21 15th August 2006 03:39 PM
The real sound is 12" driver. felixx Full Range 0 29th July 2005 07:13 AM
Copyright 1999-2017 diyAudio
