desktop TL with 3" driver (with real bass)
Old 7th June 2008, 01:35 PM   #11
gychang is offline gychang  United States
Default Re: desktop TL with 3" driver (with real bass)
Originally posted by Henkjan
I had a few starting points for the design:
- same baffle as the CT222 (a small BR with this driver)
- real bass
- easy to build
so I started the design using the allignment tables from MJK (weidok and I made a nice excel sheet that automates this) and the allignment from that (a 1:10 taper, driver at 1/3 of the line, tuning 55Hz) was the starting point for the Mathcad sheets. the 'driver offset' sheet gave very promissing results, so I made a sketch, and entered that into the sections sheet. just some tweeking and the results were imho excelent. I optimised the stuffing so I could use 1 sheet of Sonofil for each box
what mods maybe needed for TB W3-593, if any? BSC circuit?
gychang
Old 7th June 2008, 04:13 PM   #12
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
Originally posted by purplepeople
Does the line tuned much lower than the driver Fs really have that good a response or does it create ripples?
you can see the sim in the opening post... flat enough for ya ? the combination of a strong taper and the stuffed closed end does the trick.
I think this basis (~1:10 taper and 80-85cm line length, lots of stuffing in the closed end) might work with other TB drivers as well. but I expect you'll want to change the BSC somewhat.
also with the box upright, the BSC will be slightly different (I suggest to use the one for the Needle with the BB3.01 (0.56mH, 5.6 ohm, 5.6uF) in that case, BSC for the Ct222 is 0.39mH, 10uF, 5.6ohm)
the BB3.01 is a polyprop cone wide range made by TB for Blue Planet Accoustics, so availability is limited to germany and the surrounding countries. unless you don't mind paying 22 euro's for shipping them to Australia... (just PM me if you want a pair, they are very fine FR drivers, almost as good as the Vifa's for just over half the price, and 4 ohm)
Old 7th June 2008, 08:26 PM   #13
gmilitano is offline gmilitano  Canada
gmilitano's Avatar
Good work! For nearfield, you should not need a BSC.
Old 8th June 2008, 03:51 AM   #14
purplepeople is offline purplepeople  Canada
purplepeople's Avatar
... I think this basis (~1:10 taper and 80-85cm line length, lots of stuffing in the closed end) might work with other TB drivers as well.
Interesting... I had an idea for a 2.1 system using an autosound coaxial, but now with the lower response from the aggressive taper, it looks like I might be able to leave out the single woofer.
Originally posted by gychang
I have the same driver TB W3-593 looking for a small cabinet with some bass, details on your build will be appreciated if the sound was good.
gychang
I don't know how the speakers are set up now. When I left Vancouver, I gave them to my cousin who is an audio engineer with one of the local multimedia technical schools there.
When I had them, I used with my office computer. The forward port is because there are no wall in the open plan office. The low port allows some LF reinforcement from the desk surface. The amplifier was ripped out from some old PC speakers that were going to be discarded by someone else.
The line is about 23 inches long with 3:1 taper as per the MJK alignment tables. There is no BSC. Instead I used the Media Player equalizer to attenuate everything from >1 kHz by 6dB. The 1kHz slider was set to -3dB and all the lower were set to 0dB. It's actually really effective. When I really wanted to impress the colleagues, I would turn up the SRS TruBass for that fake sub effect.
The project was designed to be really cheap. It uses common pine dimensional lumber from the home improvement store. The sides cut from are 1x10 (19mm x 240mm). Front, back and all the interior panels are 1x4 (19mm x 90mm). Approx 40 drywall screws and no glue since it is small and the multiple panels make it very rigid. The stuffing is polyester blanket I found at the dollar store and fills from the closed end past the driver to the back. The last 1/3 of the line is free air.
My cousin almost cannot believe that I made them from cheap wood, cheap screws and a $1 blanket. Morever, the drivers were purchased at a discount for about $15 each. I'd say the total cost was just under $50.
I'll dig around and see if I still have the 3D model. If I can find it, I'll add some dimensions and re-post it for you.
:)ensen.
Those who claim to be making history are often the same ones repeating it.
Old 7th December 2010, 07:39 AM   #15
kstlfido is offline kstlfido  United States
kstlfido's Avatar
Sorry to bring up an old thread, but I just got a pair of the TB W3-593's for a desktop speaker project for a friend. This box looks like a simple, small-ish solution!
I'd like to possibly change the shape of the box, possibly making something curvier. What basic guidelines should this cab novice follow?
Thanks- Kent
Old 27th December 2010, 08:48 PM   #16
Henkjan's Avatar
curvier in what direction?
Old 29th December 2010, 04:18 AM   #17
kstlfido's Avatar
I don't really know, just something that steps away from the cubic form, yet easy to construct. I thought of a cylinder shape. I have some 8" (20cm) dia. cardboard tubing to test it out.
Old 29th December 2010, 02:21 PM   #18
loninappleton is offline loninappleton  United States
http://homepage.mac.com/planet10/TLS...ake_strike.jpg
This guy has a number of projects using PVC. I suppose it depends on how adventurous the design would be and for whom it's being built. These are just fun and would create conversation as computer speakers etc.
Old 29th December 2010, 10:03 PM   #19
Uncle Meat is offline Uncle Meat  Germany
Uncle Meat's Avatar
Hi guys,
I got plenty of paper tube 160/150mm. Henkjans box has 186cm area , my tubes have 176cm. Very close, so I will steal his alignment .
Building "Tube-Needles" is almost impossible, but with these short TLs it can be done, no, will be done...
Joe
Old 28th January 2011, 12:50 AM   #20
kstlfido's Avatar
Thanks for the help, folks. Sounds like 8" (203mm) dia. is too wide. Which is good, i'd like it to be a tad thinner. A 6" (152mm) tube should do OK, 181cm.
Attached is a rough idea. I have these brass endcaps with 6 bolt pattern. They would look cool!
-Kent
desktop TL with 3" driver (with real bass)Hide this!Advertise here!
Which driver is the "real" Fe103a?? Sylver300B Full Range 108 11th April 2011 12:36 PM
FS: Snell 6.5" - 7" mid-bass driver woofer feke67 Swap Meet 0 31st December 2007 07:11 PM
looking for a small 2" or 3" driver with poor bass response space-cake Full Range 3 27th December 2007 01:16 AM
"Real Life" Bass recordings gmikol Subwoofers 21 15th August 2006 03:39 PM
The real sound is 12" driver. felixx Full Range 0 29th July 2005 07:13 AM
