On my way home from work last night, I picked a single, working E-V LT-12 out of the garbage. It was bolted into a Cerwin-Vega cab. Cab's trashed, tho the tweeter might still be good.
This is a pretty nice coaxial driver, now I'm the market for a mate. I have plans on putting them into OB with some other 12" drivers to up the bass. Anybody have one before I resort to eBoy?
"Any plan where you lose your hat is a bad plan." – The Jägers |
#2 |
I have a single ls-12.I'm not sure if it would be to different from yours.It's for sale if it will work with yours.
Doug |
#3 |
Unfortunately, that is only half of an LT-12. I think the LS-12 is missing the center horn tweeter. Otherwise it would be a perfect match.
Thank you for the offer, though.
#4 |
A guy droped off a single Wharfedale 60 cabinet last week.I'll check that to see whats inside.
#5 |
Nevermind,Wharfdale speakers in cabinet.
#6 |
After some listening, I found that the tweeter would keep dropping out. The tweeter comes back if I raise the volume for a brief period. Hopefully, it is just a bad cap.
I removed the back of the driver to find the crossover as there was no instruction or other information online. I used a pocket knife to lift off the back. It was glued into place and didn't take much effort. For the benefit of others this is the back of a Wolverine LT-12 with the crossover exposed. The cap is 3uf 25v.
#7 |
Yep. Had a pair of these. On mine the caps were electrolytics, which got changed to poly's. The switch seems like a weak link and could carbon up. Interestingly simple crossover, if I recall, the switch changed the resistance parallel to the tweeter (after the cap).
I fiddled with them and built 2 way crossovers and tried a L-pad on the tweeter, and decided I liked them better just rolling off the tweeter. Mine had a peak around 6-7k (woofer cone break-up I'll guess) which I found I could null by reversing the tweeter phase, but the sound was "wrong". And lowering the crossover to reduce the peak didn't seem to work. A notch filter might have worked but I'm not that good. So I eventually went back to something similar to the original. Got rid of the switch and installed binding posts (externally) so I could easily switch the resistor parallel to the tweets. I think I was using around 5 ohm Mills. Good luck. Scott
"The Adobe Updater must update itself before it can check for updates. Would you like to update the Adobe Updater now?" -Adobe Updater |
| EV Wolverine LS12A recone? | Lee35210 | Full Range | 0 | 13th November 2008 03:57 PM |
| EV wolverine's cabinet project? | ThSpeakerDude88 | Full Range | 16 | 26th September 2008 01:52 AM |
| Electro Vioce Wolverine | crick | Swap Meet | 0 | 18th June 2008 09:14 AM |
| Wolverine LS-8 Cabinet? | jallenbass | Full Range | 10 | 17th May 2008 07:00 PM |
| Electrovoice Wolverine 8" | HiSPL | Multi-Way | 6 | 15th July 2004 12:24 PM |
| Page generated in 0.09963 seconds (75.14% PHP - 24.86% MySQL) with 10 queries |
