When playing vinyl through my FE206E's i've noticed that the speaker cones move far more excessively than when playing cd's.
Please see video here: http://www.yourfilelink.com/get.php?fid=464248 Is this likely to damage my FE206E's? |
#2 |
What cabinet design do you use ?
When listening to Vinyl, there is very much subsonic signal ( i think 'rumble' is the english word ) caused by the record/turntable system. This is because the record is crimped and excentric, because the pickups reacts on external vibration in your house and so on ... Tonearm and and pickup have a subsonic resonant frequency which is excited by that mechanism. An open cabinet like Bass Reflex or Transmission Line has no reset force for the driver at subsonic freq., which causes high excursion. Of cause this may damage your driver, when listening too loud. Too much unwanted subsonic excursion also decreases the dynamic headroom of your system and potentially the sound quality. In unlucky cases some subsonic resonant frequency of the speaker and the resonance of the turntable are close together or the same. A closed box is more benign concerning rumble, but the problem occurs anyway. There are two ways to go and they should be combined: 1) Keep rumble as low as possible. - use methods for decrimping the records (vacuum, weights ...) - use a well damped tonearm/pickup system - isolate your turntable from footfall sound 2) Use a subsonic filter. If your preamp hasn't got one use an external one, with high steepness (24db/Octave or more) But even a Passive Line Level Filter should impove the situation. You can build one easily, google for PLLXO. But you cannot achieve steepnes over 12dB/Octave using that. The cutoff frequency of the subsonic filter should be tuned to come below the cutoff of your speakers. Say e.g. 0.5 ... 0.7 * fs ( -3dB speaker cutoff frequency) This way you attenuate rumble as much as possible, while maintaining the lower bass notes your speaker is able to produce. Regards Oliver |
#3 |
Custom Title
A company named Harrison Labs has a large number of passive and active filters for high-pass (rumble) filtration. The products which I've used of theirs have been excellent.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#4 | |
Does it not sound terrible as well? No doubt the LF is inaudible but how can the driver make those sweet mids and highs when the cone has to swing so far out of the zone, and then return again? Hey, is this a joke by any chance?! |
#5 |
Xmax is only linear excursion, i.e. how far the driver will travel before distortion / compression sets in.
Whatever, you're unlikely to physically damage one of these units. AFAIK, due to the nature of their VC & suspension you simply can't drive them to Xsus under realistic conditions, so they won't bottom out. If you pump sufficient power into them you might burn out a VC, but that's not at all an easy task -they can take a lot of punishment. |
#6 | |
#7 | |
Custom Title
Exactly, it can't. Driving it out of the gap increases distortion pretty dramatically. A good metric for sufficient displacement of a speaker system is, "Can it go as loud as I listen without visible cone excursion?" Dramatic metric to be sure, and requires a LOT of subwoofer if you're running deep bass, but it's about the surest way to make sure you're operating in the happy zone. This method is best used with high Qms drivers, which tend to sound better at tiny excursions. Call it memory effect if you like, it's just my preference. Anyway, check out the harrison labs devices. In a tuned cab, not a lot of reason to allow input signal any more than half an octave below tuning.
| Gross loudspeaker cone movement when using tube amps. | colinB | Tubes / Valves | 41 | 10th July 2007 10:19 PM |
| Cone movement vs. frequency | Nichol1997 | Subwoofers | 35 | 28th November 2006 09:42 AM |
| excessive caps | moofer | Solid State | 7 | 1st September 2004 04:12 AM |
| Necessary/excessive baffle thickness | Mos Fetish | Multi-Way | 2 | 8th June 2004 12:23 PM |
| help! Dc cone movement while volume adjust. | mikee12345 | Multi-Way | 9 | 24th June 2003 02:24 AM |
| Page generated in 0.36293 seconds (25.39% PHP - 74.61% MySQL) with 10 queries |
