Old 27th May 2008, 11:50 AM   #1
Default which project for a darling amp
I've just finished building a darling amp and now I'm looking for some loudspeakers to build. I've got some previous electronic experience when building an amp so it was pretty easy but now, I've never build a speaker before.
any advice?
Is it a good idea to build a fullrange speaker for an amp that gives 3/4Watt a channel?
thanks,
michal
Old 27th May 2008, 03:30 PM   #2
Depends on the music. You can build a fullranger out of Fostex drivers that will have decent sound on lots of different music, but for full, loud rock and metal, a P.A. based 3 way will be able to run off of the 3 watts with similar or greater sensitivitys.
Old 27th May 2008, 07:12 PM   #3
gurley123's Avatar
kalinowski,
What size room are you using the system in? What type of music is dominant in your library? Also, How loud do you ussually listen? These are some of the questions you'll need to ask yourself when looking for a speaker project.
For general advise though, sensitvity is you friend here. With only 0.75 watts to play with, your going to want to get the most db's for your dollar. As a rule of thumb larger drivers tend to be more sensitve than smaller ones. You are also probably looking at larger cabs too. I've read of good pairings between the darling and the Hammer Dynamics speakers. Depending on room and listening preference though, you may be able to live happily with smaller systems. I wonder if their are others here who have a Darling who can tell us what they've driven with it?
I have always wanted to hear the Darling. I've heard a lot of good things about it. Color me envious.
Old 27th May 2008, 10:37 PM   #4
thanks for your posts.
Darling amp goes to my bedroom, it's about 20m^2 large. I listen to classical music, lots of electronic music too.
If you want to hear a darling why don't you build one? I've built mine just because I was curious how it sounds. Must say that I pretty much like it
I googled Hammer Dynamics speakers, they look great, they're indeed for owners of low powered tube amps but they're 650$ too. I'm not sure what they meant writting "Power requirements- 1 Watt RMS"
michal
Old 28th May 2008, 08:30 PM   #5
Jaime is offline Jaime  Uruguay
Jaime's Avatar
I believe you need your loudspeaker have 95 dB sensibility or more.
Fostex FE168EZ in rear horn is good option.
Fostex FE108EZ have not good sensibity.
Best regards Jaime
I write in English worse than Tarzan
A Darling.......ton Story .... sakis Solid State 19 12th November 2011 11:12 AM
Darling 1626 amp rca9449 Tubes / Valves 9 7th October 2008 05:33 PM
Next Project - Darling Amplifier or 45 Zap Tubes / Valves 5 10th July 2008 12:51 AM
Darling monoblocks Greyskale Tubes / Valves 3 13th March 2008 11:25 PM
FS... Tubes for Darling Amp RockysDad Swap Meet 0 23rd February 2007 04:03 AM
Page generated in 0.09637 seconds (65.46% PHP - 34.54% MySQL) with 10 queries
