Old 22nd May 2008, 07:22 PM   #1
sqlkev is offline sqlkev  United States
Default clarity of alpha 15 up to 1khz
I know this is a woofer, but figured many here in the fullrange forum have experience with this woofer, so i post this thread here.
I'm considering an OB with a pair of alpha 15 per side + a compression driver w/ a waveguide.
Will the alpha 15s work in this application?
Old 22nd May 2008, 08:26 PM   #2
tinitus is offline tinitus  Europe
I cannot comment on the alpha15, but anyhow with double driver used to 1khz you would have to cut the bottom woofer low ... that would be a 2.5way
With the use of RC and nothes you can go far
Old 22nd May 2008, 09:49 PM   #3
I have the dcx2696 as the processor, so 2.5 won't be a problem.
Would it be any better if i went with the MTM configuration with the waveguide in the middle?
1khz square wave ak_47_boy Digital Source 3 14th August 2008 04:18 PM
CM102 force 44.1khz apolon34 Digital Source 1 16th June 2008 03:20 PM
B&W DM602 S3 & Clarity caps kaushama Multi-Way 10 23rd June 2007 11:11 PM
Ultimate DAC - Upsampling PCM 44.1Khz to DSD proengin Digital Source 4 13th March 2006 11:02 AM
Crossovers in the 1KHz region angel Multi-Way 20 3rd April 2005 07:52 PM
Page generated in 0.07799 seconds (70.09% PHP - 29.91% MySQL) with 10 queries
