Have been pondering what to do with my group buy Jordan's for a month. Have done a lot of reading and have come to the conclusion that the cabs out there are not ideal for the "new" Jordan's specs.
So what would you do with them? My BB Ply arrives tomorrow and with the long weekend, I'm looking to build.
Hi Gary,
If you believe the recent T/S parameters measured by the hobbyists these will need a fairly large enclosure if you go ported. I have mine sealed right now, with the plan to move them to aperiodic. Sealed + sub works very well. If you go small ported you get a small hump in the bass region which is not necessarily a bad thing.
The designs based on the manufacturer's spec work fine.
Measured MLTL using a fractionally shorter version of the 48 MLTL design on the Jordan site (similar to Jim Griffin's spec). Blue line is as measured without compensation, red is with a BSC circuit in place. These are the triangular versions. I think the suckout at 150Hz was a room effect.
The plot was made on Ted Jordan's MLSSA system so someone else will probably measure it differently.
- Full Range
- "New" Jordan JX92 Cabs
