diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   Possible enclosures for a Monacor SPH 60X (http://www.diyaudio.com/forums/full-range/123400-enclosures-monacor-sph-60x.html)
everson 20th May 2008 09:24 AM
I know you`ll probably say: BIB ...
But are there any other enclosure that would work ok with this driver. Because I really don`t like how a BIB looks in a 4x5 m room.
Half-Chang?
Needle?
Thx!
hm 20th May 2008 11:59 AM
Cornet
Hello,
the Kornett,
double horn, 4,2 m horns, 82 l Volume, 17 cm wide,
i use here the Monacor as an indirect invers speaker
one the long horn.
http://www.abload.de/img/tr.hintenkornettkl.d0jx.jpg
http://www.abload.de/img/seitekornett2kl.dayzq.jpg
The front driver a TB W4-1320 is tested very well in german Klang&Ton
See more info under KORNETT
joern 20th May 2008 12:01 PM
Hi
read the Replicon-thread
http://www.diyaudio.com/forums/showt...threadid=55721
to find some information.
a simplified plan is on Till's page:
http://www.hornlautsprecher.de/projekt_alpha.htm
A german magazin Klang&Ton reported the cheap-tricks N. 193 and 194 with this speaker (mentoined in the thread above)
A more typically "resonanz-theory"-speaker with 60X is in the galery on Till's page:
http://www.hornlautsprecher.de/galerie_henning.htm
everson 20th May 2008 07:20 PM
Thank you guys!
I like the look of this "Backloaded Horn" ( http://www.hornlautsprecher.de/galerie_henning.htm ), but I don`t see any plans/specs.
As I`m a complete novice, I`d appreciate if there are any plans for these drivers.
Alpha project is good and I`ll consider it.
Replikon - I simply don`t understand it :)
Also, any other suggestions warmly welcomed.
Thanks!
joern 22nd May 2008 05:28 AM
Hi
don't worry about the replikon-thread...
the major info on the 60x ist in post 66 and 68 on page 3 (Volume und design of the horn) ;)
and that probably very close to the alpha, especially in the variation with the larger mouth...
everson 22nd May 2008 10:11 AM
Thanks, buddy!
I`ll probably go with an Alpha, as this would be my first DIY speaker, and Replikon just seems like too much for me right now.
But also, if anybody tried a Half Chang with this driver, I`d like to hear his experience ...
perempe20 22nd May 2008 10:40 AM
What about a 14 to 17 liter vented-box?
Similar designs (with more expensive Fostex drivers):
http://diyaudioprojects.com/Speakers...flex/index.htm
GM 22nd May 2008 12:43 PM
Since the 60X has proven to be a drop-in replacement for the old RadioShack 40-1354, Bob Brines' simple straight and folded ML-horn have been popular designs (especially the folded version) where high average SPL isn't a priority: http://www.geocities.com/rbrines1/Pa...ight_Pipe.html
GM
everson 22nd May 2008 02:15 PM
Thanks.
But how would that sound with monacors?
I`d like to hear anyone`s experience with these exact drivers.
Anybody tried a fonken with them?
Thanks a lot!
This what I call a project for a novice.
Although, I`m a bit worried about author`s statement that without a baffle step correction circuit"the speaker sounds thin, with little bass". I`d like not to make any circuits (no need to mention why :shy: )
Resources saved on this page: MySQL 18.75%
