#1 | |
Hi to all!
perhaps You might find this thread interesting: http://www.diyaudio.com/forums/show...threadid=121385 I propose new method of positioning of omnidirectional speakers, works with fullrange no diffusers needed explanation of attached image taken from the other thread: Quote:
graaf |
#2 |
the above is not a joke
the setup has been tested and is currently used by myself with Fostex 206E driver based loudspeakers and also by another forum user Ettienne88 with Fostex 167E best, graaf |
#3 |
Hello,
do you make any measurements to compair it? my experience with DDD driver and the TROMBONE .. has shown min. distance to a wall ~65 cm.
http://www.hm-moreart.de |
#4 | ||
I am not a technical person just a music lover although I did simple calculations of reflections showing much better (than typical) reflection delay pattern it is all discussed in the other thread in case of Your speakers an absorber on the adjacent wall can be required because of their particularly low directivity, Fostex drivers we use are progressively beaming in the high frequencies of course and also the problem of the ceiling reflection will not be eliminated (I am not sure what is vertical directivity of Your speakers) Quote:
this requirement of min. 65 cm distance in case of Your speakers is supported by the same theory that supports positioning right next to opposite walls in my proposal but, well, instead of discussing theories and measurements why not just give it a try? the proof of the pudding is in the eating happy experimenting! best, graaf |
#5 |
Here is the link to Harold Beveridge's white paper on the subject from 1976.
More info in his patents at bevaudio.com http://bevaudio.com/White_Paper.htm |
#6 | |
The idea was inspired mainly by Beveridge and also by Stig Carlsson (both given credits in my first post in the original thread at "Loudspeakers", link above) I sort of combined their approaches with the results of my own experiments it appears that true line source is not needed for it to work an omni speaker, especially a short one (Carlsson-like) and based on a appropriate fullrange driver will do the job best, graaf |
#7 |
oops, the link to orginal thread is invalid
![]() no problem, the link to the original thread once again, now valid: Loudspeakers and room as a system |
#8 | |
Hi, And the point of restarting the same thread is ?
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#9 | |
ok actually two points: 1) the original thread turned into complicated and occasionally hot discussion between us (Etienne88 and me) and Dr Geddes on this specific setup, which was not my intention, I wanted more general discussion on "room-speaker interface" 2) the topic of this specific setup is particularly interesting for omnidirectional and/or full range drivers users and the original thread may be just overlooked (because the title of it is to general) therefore I also posted a link in "DIY omni directional speakers" thread ok? am I excused? best, graaf |
#10 |
Now that your link to the other thread is working,I went back and read through it. I see you have linked the white paper several times already. Oh,well,maybe it will be of some use to others who haven't read the original thread...
A friend of mine has a pair of the Beveridge speakers,he is still waiting for Rick to refurbish the panels,so I haven't heard them properly set up yet. On my ever increasing list of things to do is build some full range(omni-directional) speakers,will have to try this placement. |
| Open Baffle Speaker Positioning | wixy | Multi-Way | 2 | 9th January 2009 11:45 AM |
| fullrange speaker for zen | metebalci | Full Range | 5 | 22nd October 2007 10:48 AM |
| How to put Fullrange speaker to a car ? possible ? | calico88 | Full Range | 3 | 21st September 2006 12:45 PM |
| Fullrange speaker, TB 3-way | J-P B | Multi-Way | 3 | 3rd February 2004 05:06 AM |
| Page generated in 0.14044 seconds (72.99% PHP - 27.01% MySQL) with 11 queries |
