I am thinking of doing a hybrid of the MJK open baffle projects that have received attention.
A Lowther DX 2, beefed up in the base with an Eminence Alpha 15 " combo, and crossed passively. Does anyone know if : 2 15" per side will be enough, and whether I should use U or H frame on one or both? Should I parallel or series the woofers? ta g |
#2 |
How much is 'enough?' Not being awkward, just that it's something of a variable point so it's difficult to answer without more specific information.
#3 |
I guess what I mean is make sure it is not bass-deficient in comparison to the > 200Hz of the DX2 (which is pretty efficient).
I can pad down the lowther a bit to suit (more than 2 woofers per side will make for a big speaker) but don't want to lose too much of their sensitivity either. Good Q |
#4 |
You'll probably gain a good bit of flexibility by multi-amping, with a separate amp for your woofers. That's really the way you should go -- otherwise level-matching will be more difficult, and require more sophisticated math. If you multi-amp, you'll be able to just tweak it until it 'sounds right'.
If it works, but you don't know why it works, then you haven't done any engineering. Taterworks Audio (nothing for sale) |
#5 |
I did some quick numbers (less than 5 minutes invested) and found that a Lowther DX2 with a pair of Alpha 15A woofers per side would work in a reasonably sized (24" x 48") baffle with a passive crossover. You would get a system with 95.5 dB/w/m efficiency down to 50 Hz where it would roll off at 18 dB/octave. If done right this could be a real interesting passive OB system.
A U frame or H frame could be used to extend the bass lower but you would need to pad down the Lowther so the final system would loss a few dB in efficiency. I would stick with the simple OB geometry. Hope that helps, |
#6 |
I have been running some sims on cuved U frames(vert curve) for OB applications using my curved mouth exit on horns programming. Its more of a tuning effect(think rear waveguide) with no resonance effect.
This was done for the accomplishment of the BVR/OB combo. Scott led me into the BVR application and i have been doing a study into the actions for various driver applications. Its interesting as there is no TL acton involved so the final action is an expansion of BR BW with a slight greater loading of the driver over a BR application (horn loading). ron |
#7 |
What about this baffle?
![]() Mods: 1 - Bi-Amping 2 - Active filters (or digital filters from PC) 3 - 8" Fullrange high sensitivity (I have a couple spare FE206) instead of the Seas 90 dB mid driver 4 - 2 pairs of Alpha 5 - (optional) a pair of high efficiency compression drivers (B&C DE250?) Target would be very high SPL at listening position. Would the Alpha be enough? |
#8 | |
Dave |
#9 | |
speakers with high spl is ok, you don't have turn the amplifier way up, listen at low level is still ok! |
#10 | |
| Why don't more of us use the 10" Eminence? | Godzilla | Full Range | 8 | 8th March 2010 03:34 PM |
| What should I do with these? (15" Eminence) | fusion | Subwoofers | 13 | 13th January 2007 08:48 PM |
| Enclosures for Eminence Sigma 18" and/or Eminence Kilomax 15", PA-sub application | esaias | Subwoofers | 8 | 10th August 2005 05:17 AM |
| New Eminence "line-array" series? | Ap | Multi-Way | 0 | 5th May 2004 12:53 AM |
| Which Eminence 10" | JDeV | Instruments and Amps | 1 | 6th July 2003 06:50 PM |
| Page generated in 0.11369 seconds (75.72% PHP - 24.28% MySQL) with 10 queries |
