Old 21st April 2008, 03:06 PM   #1
Default OB FE126e with Dual Alpha 15a
I have a pair of FE126e and would like to try MJK's dual woofer open baffle with the Alpha 15a's. Could I use the same crossover point as shown in the pdf. 300hz HP and 200hz LP. I get component values of 33uf and 8.5mh for the HP, and 50uf and 12.5mh for the low pass. I have sent MJK the money for a license for the sheets, but I am not quite sure what I should do with them when I get them. Any help would be appreciated. Another option might be this 15" pa woofer.
http://www.shredmuzic.com/product_p/813-013.htm
spl is 101; qts is 1.006; fs is 35hz.
Thanks in advance.
Chris
Old 21st April 2008, 05:53 PM   #2
nicoch58's Avatar
and Cast Aluminum Basket....
good on the paper
Sic58
Old 21st April 2008, 06:19 PM   #3
frugal-phile(tm)
planet10's Avatar
very interesting woofer... not much more expensive than the Eminence. Different parameters would mean a need to remodel the works, but that is what owning the sheets is for...
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
BIB for FE126E blasko Full Range 2 31st August 2007 04:23 PM
Help!---which t-nut is for FE126E pwan Full Range 7 11th August 2007 03:34 PM
Yet another Fe126e mod! dfreemansc Full Range 46 29th January 2007 03:54 AM
Here is what I did with my FE126e's audiophile36 Full Range 6 27th October 2006 03:16 PM
WTB: 10K Alpha pot, dual log taper KT Swap Meet 3 11th May 2006 03:01 PM
Page generated in 0.06983 seconds (67.68% PHP - 32.32% MySQL) with 10 queries
