Old 13th April 2008, 08:40 AM   #1
lepomis is offline lepomis  United States
Default TABAQ and Needle hybrid
I am working on a blend of the needle's speaker placement and TABAQ's box.
Looking at these two builds on here for the last few weeks made me have to buy MJK's worksheets. (Big thanks to all 3 of you guys )
This is what I have come up with so far.
I used a 4.5 FE127E to see if I could get away without using a subwoofer. I first tried using tang band's 4 inchers, but I could not work them out in MJK's worksheets very well. This fostex seems ok, possibly due to its higher Qts. This will be the first speaker I have tried to make, so I could be using the software wrong or not taking the design far enough.
I want to keep working on this for a while, but am not sure when I should stop and just build it
I would love any suggestions or ideas.
Old 13th April 2008, 03:42 PM   #2
gychang is offline gychang  United States
Default Re: TABAQ and Needle hybrid
graph looks good... build it?
gychang
Old 13th April 2008, 04:59 PM   #3
Hi Lepimis, it would be interesting to see your data entries for MJK spreadsheets. When I designed TABAQ I also wanted to place the driver higher up in the cabinet. However, this gave uneven response, which I elemintaed by moving the driver one third down in the pipe.
Hi from Bjorn
Old 13th April 2008, 05:45 PM   #4
Svein_B is offline Svein_B  Norway
I have been pondering almost the same design, since i have a couple of spare W3-871s (in addition to one pair of good sounding needles).
Attached is a MLTL sim I did with the TB W3-871s.
height= 30"
cross-section= 4 x 5"
sd= 4"
port: 0.88x3.8” , 2” from bottom
stuffing: 0.9 lb/ft3 in upper half.
The plot looks almost identical to Bjorn's TABAQ sim.
Svein.
Old 13th April 2008, 09:10 PM   #5
Svein and Lepomis - thanks for you input.
You guys are absolutely right, you can move the driver in TABAQ to the top of the cabinet with no problems.
I could not resist firering up under MJK software to take another look at it.
In an ustuffed line, the driver should remain as is. But since the cabinet is hard stuffed (0.207 lb - with the last 10 inch unstuffed) you can place the driver higher up.
The design of TABAQ (and others) is a repeating process. I start with an unstuffet design, trying to make this as good as poosble. Then i stuff, playing with density and distribution. But in this case, i simply forgot to see if the driver could me moved after the stuffing.
Sorry about this confusion.
Hi from Bjørn
Old 13th April 2008, 09:15 PM   #6
Hi Bjorn
I tried to email you the sheet, but I do not have enough posts yet to use that feature. Would you just need the section numbers?
Hi from Bjorn
Old 13th April 2008, 09:15 PM   #7
I see you just posted Bjorn... so I guess you don't need it anyway
Old 13th April 2008, 11:48 PM   #8
height= 30"
sd= 4"
Svein.
Would the same dimensions work for another TB driver W3-593SF instead W3-871? (I have 2 in storage). More details here.
http://www.partsexpress.com/pe/showd...number=264-809
gychang
Old 15th April 2008, 07:13 AM   #9
The driver specs are slightly different, but very close. In MJK's worksheet the frequency graph does not change with either driver. I guess it should work
gychang
Old 15th April 2008, 08:27 PM   #10
almost a simple box, will try it soon. Are the measurements inside size?
gychang
TABAQ TL for Tang Band Bjohannesen Full Range 323 8th May 2012 05:11 AM
Tabaq to the future. raypalmer Multi-Way 7 6th April 2009 03:59 AM
My TABAQ Build Thread Consul Full Range 17 3rd September 2008 09:50 PM
Cheap and simple DIY amp for 2x TABAQ Lifthanger Chip Amps 5 14th February 2008 12:41 PM
Folded TABAQ BoomieMCT Full Range 3 7th July 2007 10:08 AM
Page generated in 0.19030 seconds (57.34% PHP - 42.66% MySQL) with 11 queries
