Old 17th September 2010, 10:50 PM   #401
RSR is offline RSR
PLEASE BE A WIRE BUSTER
I think the famous Rogges Russel spent years of their life designing speakers and other REAL, LISTEN... REAL hi fi equipment, not "marketing hi fi"
read part of the site of Mr Rogger
"We have been told by advertising that the exotic speaker wires offer fabulous advantages over ordinary lamp cord. It would seem reasonable that using this same wire for lamps would also enhance their performance. In the same vein as wire literature, you can have your lamp reproduce light with the full spectrum color fidelity of natural daylight........."
hahaha
I think it so
read the full article here Speaker Wire
CHEERS
Old 22nd March 2012, 08:17 PM   #402
fakeout is offline fakeout  Canada
fakeout's Avatar
I hope I'm not committing a booboo by bumping this thread. But, assuming I can find 14ga single stranded copper wire, what to do with the other wires? I mean if I go 14ga single strand from amp to speakers, then on a T-class amp you also have to hook up with let's say a 3.5mm male to RCA. Is there a way to connect 3.5mm and RCA jacks to 14ga single strand wire?
Old 22nd March 2012, 09:10 PM   #403
wire is wire, so thick wire has less resistance than thin wire, so buy a half decent thickness and job done. any benefit from solid gold wire is marginal and probubly only placebo, noticed...
Old 22nd March 2012, 09:17 PM   #404
i would love to see one of these cable fanatics do a blind listen test with 2 sets of identical speakers, and a speaker selector, on the same amplifier
one wired with telephone wire.. ok thats a bit to far
ok
one wired with standard power cord form spare computer leads (what i use.....)
and one wired with oxgen free super conductive bla bla £200 wire
any money says then wouldnt know which was which
there are far more factors in play, a good set of speakers is upmost and a good amp, and cord?? it needs to be a conducter... its as simple as that
Old 22nd March 2012, 09:20 PM   #405
this is halirious... sucker bait, lol
http://gizmodo.com/302478/7250-speak...sspeakercables
must be for rich people who have run out of things to spend money on, so they get a pear wire to match there pear shaped figure
ive just read this... absolute stupidity, they really go on about rubbish,...
http://www.pearcable.com/sub_products_anjou_sc.htm
Old 22nd March 2012, 09:59 PM   #406
Bob Brines's Avatar
Let's assume just for a minute that this post is on the level and the poster actually want to use 14ga solid wire. The easiest source of this is Romex cable, i.e. household mains cables. Romex has been discussed elsewhere for speaker cabling and I am sure that there are a small number of systems using 14ga or even 12ga Romex. The immediate problem of using 14ga with RCA's and 3.5mm stereo jacks is that 14ga wire is half as thick as the 3.5mm jack and there is no way to squeeze three 14ga wires into the jack housing. End of discussion.
Let's assume that the poster actually meant 24ga wire. This would be appropriate for a T-amp in a rig that is using a stereo plug to connect components. The only problem with using 24ga singly to a RCA plug is to provide adequate strain relief. A single 24ga wire will have a pretty fragile joint in the plug housing.
Oh, well.... Too much time on my hands.
Old 22nd March 2012, 10:44 PM   #407
fakeout's Avatar
Uh, OK. But, I thought Planet10 uses single stranded CAT5...
Old 22nd March 2012, 11:24 PM   #408
Bob Brines's Avatar
He does, and so do I. That's 24ga not 14ga.
Bob
Old 23rd March 2012, 12:19 AM   #409
zman01 is offline zman01  Bangladesh
Quick and dirty way to convert RCA into stereo. So you can fashion a pair of interconnects with CAT5 and use this. Is there any degradation of SQ because of the converter? Really dunno...
Old 23rd March 2012, 07:38 AM   #410
frugal-phile(tm)
planet10's Avatar
What Bob says.
To expand on the strain relief issue: It is pretty easy to nick the solid cable when you strip it -- this leads to wire failure. Even with no nick the stuff can break. For speaker cable i terminate it in Pomona dual bananas since we switch speakers a lot. Every 3 or 4 months a channel will go down -- the 1st place to check is the 24g solid going into the Pomona. 99.9% of the time it is a broken wire. Most of the time at the speaker end where it gets stressed.
If you are making interconnects it doesn't hurt to "wrap" it around a substrate (send & return crossing at 90 degrees). The substrate can be a piece of teflon, another wire, Chris has used PVC fish tank tubing... you then have something for the heat shrink to hold onto for strain relief.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
litz inductor wire for speaker wire. fazman Everything Else 126 20th June 2011 02:48 PM
Favorite Speaker Wire -- Part 2: Insulation Bob Brines Full Range 37 4th February 2010 05:49 PM
22 AWG silver plated solid copper wire for speaker wire? G Full Range 21 15th February 2009 09:32 PM
Favorite size wire for signal wiring? G Tubes / Valves 8 12th February 2009 05:19 PM
Page generated in 0.13886 seconds (74.43% PHP - 25.57% MySQL) with 11 queries
