fostex grille - any good? - Page 2 - diyAudio
Old 11th April 2008, 02:19 PM   #11
No, the grilles are kinda square with cut-off corners. Or at least the frames are that way, the actual grille is round ok.
I think I'm just gonna buy the fostex ones. Its only really for protection when I'm not around - I don't intend having them on when I'm listening.
Fran
Old 11th April 2008, 11:48 PM   #12
Well I bought the fostex grilles from madisound, so I'll let you know how they work out....
Fran
Old 31st July 2012, 02:53 PM   #13
Long overdue update.
I bought the grilles, they only bolt on through the same holes in the chassis. Don't seem to have any effect on sound, fit across the front of the fonken (close enough though) and only look OK. Keeps the driver safe though......
I'd say a home built solution of a fabric covered frame would be much nicer looking, but for a quick build these work fine....
Fran
Old 31st July 2012, 06:15 PM   #14
Bob Brines's Avatar
You can put neo magnets in the screw holes of the grill and they will stick to the driver mounting screws. The holes are 6mm, so 6mm magnets will be a slip fit and need glue. 1/4" magnets are a tight press fit and need not glue.
Bob
Old 1st August 2012, 02:21 AM   #15
adamt is offline adamt  Australia
What I did was put some blue tack underneath the grill and just press it onto the speaker frame. Then when I have a listening session, I just pull them off. The screws i used were non magnetic, so magnets would not work. I have young children (now 5,8,11), and they never touched the cover even when they were younger. Just the sight of it put them off I think.
Worth a try?
Adam.
Old 11th December 2014, 07:23 PM   #16
Default Grill magnets
Do the magnets in the grill not affect the driver?
Boxertwin
fostex 208ez and fostex ft17 h good kombo? almightybozo Full Range 1 24th September 2010 07:00 PM
Custom Speaker Grille morfius Multi-Way 6 22nd March 2008 11:55 PM
heavy duty grille. matteroftaste Multi-Way 0 24th May 2007 02:32 PM
Grille Beams stelleg151 Multi-Way 7 31st July 2006 05:31 AM
6.5" behind 4x10 grille curtis73 Car Audio 0 24th March 2005 09:32 PM
Copyright 1999-2017 diyAudio
