fe167e and Alpha 15a OB arrived
Old 8th April 2008, 01:04 PM   #11
skorpion is offline skorpion  Sweden
Dead sure ! I can recommend the Obbligato capacitors. They are also a favourite in Tony Gee's Cap test: http://www.humblehomemadehifi.com/Cap.html . Use 10 Watt low inductive resistors.
/Erling
Old 8th April 2008, 02:23 PM   #12
Vix is offline Vix  Yugoslavia
Vix's Avatar
Or, there's and alternative to an L-pad: Semi-active approach.
Use two amplifiers. Run them from the separate preamp. One of the amps could be an "integrated" one, so you can adjust its volume compared to another amp. Use passive crossovers, as before.
This solution has some advantages:
You can increase the level of the amp driving Alphas, to match the level of the amp that drives Fostexes, resulting in higher overall sensitivity. You can use your tube amp just for the Fostex, and can use some high-powered SS amp for Alphas. You get better bass and also midrage may sound better since the crossovers are separated;
If you don't have the separate preamp ouputs, you can "tap" the bass amp from the output of the tube amp, before the high-pass crossover...
All you need is another SS amp...
Of course, you can use active crossovers, but that's another story...
Old 9th April 2008, 02:16 PM   #13
AudioGeek is offline AudioGeek  United States
so before i order parts for x-over... can someone confirm that the prior mentioned values for low pass and high pass will work?
i want to run the setup from one amp so going seperate amps will not work.
and i want to stay passive.
thanks for all your help
It is not you... you are it.
Old 9th April 2008, 09:18 PM   #14
Richard,
The values are OK. But alternative L-pad values of 2.7 and 15.5 ohms will give 3.6 dB damping which may be a better solution to start with and adjust further if necessary.
If you would go for cheaper high-pass you could choose Dayton DMPC-30 30uF 250V Polypropylene Capacitor at Parts Express(which I don't know the quality of) and later upgrade to Qbbligato if you are not satisfied.
/Erling
Old 10th April 2008, 07:58 AM   #15
Richard,
Another way to choose to take down the Fostex would be to place just a resistor in the signal lead before the High Pass capacitor crossover component. 4 ohms would be a perfect value.
/Erling
fe167e and Alpha 15a OB arrivedHide this!Advertise here!
Zen#9 is arrived ! gionag Pass Labs 17 6th October 2008 06:58 PM
my fe167e and alpha 15a combo and ? AudioGeek Full Range 1 21st September 2008 01:09 PM
New toy has arrived! I_Forgot Digital Source 0 1st February 2008 12:57 AM
Just arrived marcograziano Introductions 1 16th December 2004 11:52 AM
New parts arrived & will foloow with kit, !!!!S1 12pcs arrived from Holland!!!! tube-lover Swap Meet 1 3rd September 2004 11:29 PM
