Old 30th March 2008, 11:21 PM   #1
Default DIY speaker wall mounts for b3s
I have been looking for a sturdy cheap speaker wall mount for my B3S's I DIY and couldn't find any that I felt was worth the price they where selling their plastic for so I designed a set of my own. Mind you these are in the roughed out stage of development and require some serious grinding down and drilling of holes. I wanted to bounce these off of you guys for ideas.
I guess Ill have to widen out the wall base abit so it does not punch through the sheet rock. Im guessing this should hold up 6 lbs. I bent 1/8"x3/4"x3' flat iron bar. The bar costed me $3.50 at loews. If this works it should beat the hell out of what is being sold online.
Old 30th March 2008, 11:25 PM   #2
If you noticed that the top and bottom 90* are going to be high stress points you are correct. Im going to double up on stock in these areas.
Old 30th March 2008, 11:27 PM   #3
I have to trim the bracket attached to the speaker. I will hold this bracket up with two bolts and the c shaped bracket will have multiple holes drilled so it can be adjustable. The speaker will sit 6" off of the wall.
Old 1st April 2008, 12:11 AM   #4
I managed to work on the bkt some this evening. It is very sturdy I think if I put this on some sort of base it will stable diagonal wiggle. Ive been thinking about a finish to put on this bkt. Im leaning to a hammer tone finish in the same color as the speakers. Ill take a ball peen hammer and put dimples all over the bracket. Then I will have to prime and paint. Anyone have any ideas?????? Comments???? Complaints????? Dont be shy.
Old 1st April 2008, 12:12 AM   #5
This speaker is just a test box. I added a small piece of concrete inside for more weight just to test bkt over nite.
Old 1st April 2008, 12:13 AM   #6
And another view
Old 1st April 2008, 04:51 AM   #7
despotic931's Avatar
Send a message via AIM to despotic931
sweet! i can't wait to see the finished product, keep us updated!
Old 1st April 2008, 08:26 PM   #8
despotic931 Thanks for the encouragement. I messed around with the finish today by thumping out a test piece. I can see how metal working could be fun. I was abusing a couple pieces of metal just for the fun of it. I used a punch, chisel, piece of concrete, axe, a claw hammer and every one looked different. I ended up liking the plain ole ball peen hammer finish. take a look.
Notice how plain the metal looks comared to the mared finish.
Old 1st April 2008, 08:28 PM   #9
Here is a close up.
While walking around in loews I happened across a copper grounding rod and the wheels started turning. I bet I could get a nice ark out of that rod and the bracket attached to the speaker could float along the rod. Not to mention that copper can be varnished. Hummmmmm.
Old 5th April 2008, 09:36 PM   #10
Ok I had some time to mess around with my bkts again. I picked up some 2" wide stock to widen the wall base so I wont have to repair sheet rock. I managed to fabricate 3 bases today.
Take a look.
Designing for on-wall/near-wall speaker placement morbo Multi-Way 4 27th November 2010 04:52 PM
FE127 for in-wall speaker? Xor Full Range 8 30th May 2007 03:25 PM
in-wall/on-wall speaker? (axiom w-22 clone?) Scott_fx Multi-Way 0 22nd February 2007 02:08 AM
new on-wall speaker for selection denbo123 Multi-Way 0 3rd August 2006 02:30 PM
In-wall speaker recommendations? Bill F. Multi-Way 4 21st January 2005 11:40 AM
Page generated in 0.14846 seconds (58.59% PHP - 41.41% MySQL) with 11 queries
