Old 2nd April 2008, 03:20 PM   #21
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
Originally posted by loninappleton
What's a pincushion?
Rotozip-type tool has real high speed and I steadied it as best
I could.
A word of caution: Many cheap router bits aren't rated for the rotozip's speed. I don't like the idea of a bit flying apart. I know it doesn't spin nearly as fast under load, but I only use bits rated to 20,000 rpm. Also, the real weakness isn't the rotozip jigs or any other, its the tool's stock base. I'd imagine it would work much better with the router base attachment.
AFAIK, 'pincushion' refers to drivers shaped like this:
http://www.partsexpress.com/pe/showd...number=295-300
You can't use a circle jig to cut that recess.
pj
Old 2nd April 2008, 03:32 PM   #22
Originally posted by Henkjan
there are plenty DIY circle jigs around
like here (it'sin german)
http://www.uibel.net/bauvor/bv_tutor...rkel/d_fz.html
That looks like a good shop built system for a small router or rototool.
The small rototool or laminate trim variations as small routers
(unlike the Trend or that Bosch shown) don't all have base plate machining to attach a jig with screws. Routers don't come around for sale as used very often. The Bosch shown will have better availability than the Trend. I haven't seen or noticed one just like that.
Old 2nd April 2008, 06:11 PM   #23
Colin is offline Colin  United Kingdom
If in doubt, cheat ... I usually jigsaw holes and don't worry about setting the driver flush but for my next enclosures I'm going to ask a local wood turner to make a pair of circular hardwood sub-baffles. They will cover the wobbly hole and the driver will fit flush into them.
Old 2nd April 2008, 06:31 PM   #24
gareth is offline gareth  Wales
gareth's Avatar
You could get some 6/8mm steel rod and put a tight bend at one end making sure it is at 90° and with enough length, 2-3", to go through most baffles. I think most routers have trammell holders on the base that can be used.
Gareth
Old 4th April 2008, 05:18 PM   #25
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Default Re: What tool for Cutter baffle holes
Originally posted by kvk
I supposed a Jasper Jig is probably the best tool for routing baffle holes for drivers but it's about $40 which is a fair amount if you are only building one pair of speakers.
Are there any cheaper options? Does someone make something like a cheapo adjustable jig for routers?
I do have a router and bits already.
One pair...right
Once you get into DIY, just doing one is hard
Jim J.
Who can cut holes? smellygas Multi-Way 8 2nd August 2009 08:17 PM
How do I repair a crack between driver holes in a baffle? GuyPanico Multi-Way 5 12th July 2005 06:19 PM
Is Rotozip a good tool for cutting holes? AJ Bertelson Multi-Way 10 9th June 2004 07:36 PM
Edge diffraction: large, rounded baffle, or narrow square baffle fortyquid Multi-Way 12 12th January 2004 03:43 AM
Demagnetising Tool/Tool Demagnetiser mrfeedback Everything Else 30 4th October 2002 11:53 PM
Page generated in 0.17885 seconds (44.38% PHP - 55.62% MySQL) with 11 queries
