Old 24th March 2008, 05:06 PM   #1
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
Default simulating variovent with MJK sheets?
I am designing a pair of speakers (using the FR125) for my 11 year old daughter. since her wish is that they should not be too large (yes, this sh*t starts already at a young age), I thought of making a aperiodically damped (aka variovent, aka controlled leakage, etc) CB. (I first proposed the miniOnkens, but even these were considered too large)
a thought came in my head to use MJK's mathcad sheets for this, using the BR sheet and then "applying" damping material in the port to simulate the variovent.
anyone has ever done this? @MJK: do you expect this to give good results? and related: in your sheets you give 1 lb/ft³ as max damping material density, why's that?
Old 24th March 2008, 06:46 PM   #2
gurley123's Avatar
I'm not sure about simulating aperiodic vents. I've yet to use the mathcad sheets. However, according to the last few posts by Planet 10, many are now perfering the 4.5 liter aperiodic cabs for the FR125. These are a bit smaller than the MiniOnkens.
Maybe she'll like those?
Old 25th March 2008, 07:31 PM   #3
Henkjan's Avatar
that should give a starting point as well as a fall-back position... thanks.
I'll start the design on the speakers in a week or so (want to finish a pair of table-top TLs first) so if anyine can add some thoughts on this, please do so... and if I'm the 1st to try this, I'll report back here about the results
Old 25th March 2008, 07:33 PM   #4
Henkjan's Avatar
the design is more or less agreed apon, it will not be the average sqare box....
Old 25th March 2008, 07:42 PM   #5
gurley123's Avatar
I'm glad it worked out for you.
11 yrs old and already getting a good set of speakers. That's too cool. My little sister is 17 and I don't think she's heard a decent stereo yet (we never lived in the same house, or else she would have.)
I'm toying with the idea of making her a cool little mini system with some cheap fullrangers and a tripath amp. Looks like it could be fun.
Old 25th March 2008, 08:24 PM   #6
Henkjan's Avatar
well, I have to admit it was the special design I have in mind and the FR125's good looks that made here give in (I had been trying to build a pair of decent speakers for her for a long time already, but she's not realy into music yet), but I'm sure she'll appreciate the result when they are ready
Old 26th March 2008, 05:19 AM   #7
maxro is offline maxro  Canada
maxro's Avatar
Default Re: simulating variovent with MJK sheets?
The 'ported box" work sheet allows densities over 1lb/ft3 in the port section. IIRC, Planet10 had mentioned some reservations about using this method for aperiodic simulation, but I think it to be the best solution thus far. I guess the question is: what is the stuffing density of a Variovent?
"Part of the reason a poot into a toilet bowl sounds the way it does is because of phase shift." -Andrew Eckhardt
Old 26th March 2008, 08:57 AM   #8
Scottmoose's Avatar
Depends on what's required. You can sim aperiodic well enough using Martin's sheets.
Old 26th March 2008, 09:27 PM   #9
Henkjan's Avatar
OK, let's fire up the quattro uh mathcad
Old 26th March 2008, 11:28 PM   #10
Scottmoose's Avatar
You've been watching Ashes to Ashes haven't you?
Simulating MTM,MMT,etc? kyrie48 Multi-Way 5 26th January 2009 11:43 PM
How to calculate an enclosure with variovent ? TomatoBangBang Multi-Way 4 16th January 2009 04:35 PM
Modeling a variovent pjpoes Subwoofers 7 21st February 2007 03:17 AM
Dynaudio Variovent vs. Scan-Speak Vent amichalik Multi-Way 1 11th June 2006 01:42 AM
Variovent placement... arcturus Multi-Way 12 16th October 2004 03:46 AM
Page generated in 0.13230 seconds (66.89% PHP - 33.11% MySQL) with 11 queries
