Basket, magnet & frame damping: How to?
Old 24th March 2008, 12:32 AM   #21
LineArray is offline LineArray  Germany
Thanks !
And it works real fine. This is the first
speaker i built, which statisfied me in bass and
lower midrange performance. It is very "quiet"
concerning basket or baffle resonances.
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 25th March 2008, 10:19 AM   #22
Zero One is offline Zero One  Australia
Hey LineArray
Great idea and I am sure it works a treat. I am currently building an open baffle system where the 4x 12in woofers are mounted in a similar way. IN my case I built 2 concrete block columns then mounted the drivers in a MDF cradle, which then attaches to the column but is slightly de-coupled by felt pads. The actual baffle does not touch either the column or the cradle. The drivers shown in the pics I attached earlier in this tread sit on top of the columns.
The only thing we need to be careful of with magnet mounting is to make sure the rear vent on some woofers is not covered, this is rare however and most unusual on mids. In your case the cold mass of the marble would help wick away some heat from the drivers, which is hardly an issue in your application but could help with bass drivers that are being pushed to their thermal limits.
I will try to grab a pic tomorrow and post it.
Elbert that bitumen stuff is very good, some neoprene or rubber non-slip matting added over the top of it might work even better still as it will stop reflections as well as damping the resonances from the basket.
Old 25th March 2008, 01:44 PM   #23
Hi Zero One,
you are right, thermal limit is not an issue with the
current system. The FR125s is vented behind the spider but
not through the pole piece. Anyway mechanical limits are
the limiting parameter depending on subwoofer and XO frequency chosen.
I am v e r y curious about your pics, hope you find and post them.
Oliver
www.dipol-audio.de
Old 26th March 2008, 08:43 AM   #24
Hi LineArray
Here is a pic of the woofer mounting, note the following.
The woofer is glued by the magnet into the assembly and mounted at the front also, it is for all intents and purposes a homogenous construction.
The assembly is isolated from the concrete block column by heavy felt pads with just enough give to absorb vibration without driving it into the column.
Old 26th March 2008, 10:05 AM   #25
Just for a little perspective here is a pic of how the top baffle locates and with one of the bass baffle wings leaning against the structure.
Obviously these are very large speakers, fortunately I have my own dedicated listening room so WAF is not a problem.
Basket, magnet & frame damping: How to?Hide this!Advertise here!
Basket damping mods.. JandG Full Range 5 31st January 2014 01:22 AM
Bracing driver to box, deadening basket and wrapping magnet in felt tsnell Multi-Way 2 18th October 2007 02:33 PM
FR125s frame/magnet damping Foxx510 Full Range 3 6th August 2007 02:02 AM
Coral Flat 6 - magnet/frame seal problem. nodiak Full Range 6 12th February 2007 02:12 AM
