Saw this image in another thread. That looks like a cool way to build a speakers in layers like that. If you didn't have a lot of precise tools, it might actually be easy to build one template and then use a router to but the final shape of each strip.
Anyone know of any plans online for an enclosure like that?
#2 |
I believe this is actually done with a CNC machine
#3 |
It can be done with a cnc router or mill, if you have one (or put the 'ware on your existing machine), and have the 'ware to generate the cut. In hobby and small-shop practice, it's more often done with a router pattern, or even a jigsaw and a little elbow grease.
I object to it because, unless we are very clever with design and layout, it's extremely profligate of material; our waste pile is going to be twice the size of our piece pile. That said, it is one of the very few practical ways of getting certain shapes, like horns, without a great deal of time and skill. I like kerf bending for a lot of this sort of work myself, but that method is not without it's shortcomings as well. Aloha, Poinz |
#4 |
frugal-phile(tm)
search on translam or layertoning (the last a word i coined after Tony's moniker which as of the latest aXP (IIRC) is now officially part of the lexicon).
You can see examples of Tony's brilliant work on the Full range forum, and Andy Graddon has a part of his site dedicated to boxes that aren't monkey coffins -- a number of those translam construction. dave PS: i have the same objection as poinz... and if not done in a considered fashion you can end up with a box that doesn't have as good a sonic signature as a box made the old fashioned way.
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
Why would you have a total flat reflector directly behind the driver?
ron |
#6 |
And again, the aspect ratio of the mouth really need correction for proper wave launch.
ron ( i may be slow , but i am steady) |
#7 |
I think someone made a frugal horn in that method, I had it for my wallpaper for a while.
It's not for the faint-hearted KVK, it takes a lot of wood and work and it's going to be damn heavy. Personally I love the look of it and a set of curvy changs in plywood made like that would be glorious. I don't trust myself not to change my mind about what cabinets I want so I'm not game to start.
Help some guys with funny hair bang two rocks together really hard. http://athome.web.cern.ch/athome/LHCathome/whatis.html |
#8 |
Nice design - could be fun to build a pair like this just wonder why the designer have made this combination of nice curves and sharp edges ?
Frandsen |
#9 |
My Home Site & Favorite Battleground |
#10 |
These would clearly be very wasteful if each slice was a full profile, but don't I see joint lines in the picture that indicate the slices are built up from smaller pieces? With a good layout, I'd think a CNC could cut that all out pretty efficiently. I don't think I'd try it with a router and template.
The difference between theory and practice is that in theory there is no difference between theory and practice, but in practice there is. |
| search for very thin (open pores) foam layers | Calvin | Planars & Exotics | 20 | 16th April 2007 09:33 PM |
| Cabinet construction started - additional absorbent internal layers? | quickshift | Multi-Way | 8 | 26th February 2007 08:08 PM |
| Splitting sound layers off of a CD? | devroger | Digital Source | 5 | 17th February 2007 05:22 AM |
| Peerless CSC and Vifa TC assymmetrical layers of VC windings | capslock | Multi-Way | 21 | 29th November 2006 12:32 PM |
| Creepage distances in PCB internal layers | Jaka Racman | Power Supplies | 6 | 26th October 2005 02:34 PM |
