Any enclosure ideas for the "new" JX92S? - Page 3 - diyAudio
Old 27th March 2008, 11:46 AM   #21
Colin is offline Colin  United Kingdom
I've been in touch with Ted Jordan and alerted him to Zaph's findings, in case anything is going adrift with current units.
The first thing he noticed was that the web published spec was out on resistance and should read 6 ohms, not 4.5. Department of mea culpa as that typo was probably mine when I worked on the site. The published spec will be updated.
Ted is going to pull out a recent sample JX92S and check the spec. I'll post here when I hear from him. (Ted prefers not to join in the forums.)
Old 27th March 2008, 02:37 PM   #22
I hope the discrepancies will have no siginificant impact on, for example, GM's MLTLs dimensions. I am about to finish gluing the 31' version and would be very sad to know at this stage that the measures should be different.
Old 27th March 2008, 05:23 PM   #23
GM is offline GM  United States
GM's Avatar
If the other specs are 'correct', then the slightly increased BL in theory is an improvement, though I seriously doubt it would be audible in-room with any TL, MLTL alignments and my SWAG not even the tiniest sealed ones.
Anyway, looking forward to his thoughts/findings on the subject.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 27th March 2008, 05:28 PM   #24
GM's Avatar
Worst case scenario based on my comments here is you may want to either increase the vent length some or add a bit of stuffing inside the existing one to suit, though I imagine had these specs discrepancies not been noted you would be pleased with the design as is since the room dominates the BW they affect: http://www.diyaudio.com/forums/showt...91#post1465991
GM
Old 7th April 2008, 03:47 PM   #25
gmilitano's Avatar
Is there any update on this? I had emailed them on March 25 and sadly there has been no response.
Perhaps I am thinking about this too much.
If you take the specified Qes = 0.58 and Qms = 1.35, I calculate Qts = 0.406 which matches the specified Qts = 0.4.
However, using the specified Fs = 45 Hz and Vas = 15.28, I calculate SPL = 85.84. Jordan has specified 88.
Is this another typo, or is it possible that have they used a specified SPL to calculate Vas?!
Am I making too much out of this? Is a 30% variation Qts no big deal?
Also, note that their impedance plots are only from 30 Hz to 10kHz. Is this why they have Re = 6 and others are measuring closer to 5 ohms?
Old 7th April 2008, 04:02 PM   #26
No update received yet. Jordan commercial business is handled by EAD or the distributors. Ted is mostly consultancy now. As soon as I hear anything from Ted I'll post here.
This month's HiFi News review of the Aurousal A1 mk 2 seems to fit with the Jordan sensitivity, as far as I can tell. The mk 2 features the recommended BSC for the 8 litre enclosure so loses 3-4dB from the raw Jordan spec.
Old 7th April 2008, 04:21 PM   #27
jkeny is offline jkeny  Ireland
Banned
As per the title of this thread, I'm embarking on an enclosure that has not been tried before with the JX92S drivers, AFAIK (mine are not from the GB) - see the thread here: 3D Spiral Horns Anyone?
The final version I am having built, by the kindness of WoddturnerFran (as the name suggests he's a dab hand at wood & just finished some Fonkens), is this one: http://spiralspeaker.web.fc2.com/aaa...ng-ag180z.html
These cabinets are originally for the Fostex FE126E drivers & I'm wondering what, if any, changes to dimensions should be made?
Any comments/changes appreciated before wood is cut,etc?
Old 11th April 2008, 09:50 AM   #28
Banned
Built these & initial reports are good: http://www.diyaudio.com/forums/showt...49#post1481149
Old 25th April 2008, 03:26 PM   #29
Did it Himself
richie00boy's Avatar
How are you calculating Vas given Fs and sensitivity?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 28th April 2008, 01:38 AM   #30
gmilitano's Avatar
You can calculate efficiency with Fs, Vas and Qes. You have to assume a density for air.
http://en.wikipedia.org/wiki/Thiele/Small
Looking for phase plug ideas for horn loaded 10" and 12" drivers Eva Multi-Way 10 11th December 2011 05:17 PM
Using a standard pentode-tetrode as output "space-charge tube" any ideas-experiences? bembel Tubes / Valves 12 11th March 2010 05:56 AM
Charcoal "Supreem" hi-density foam "enclosure" IG81 Multi-Way 0 23rd April 2009 01:34 PM
2x18" + 8x8" = any ideas? Happy New Year! Jezz-the-Fezz Subwoofers 0 31st December 2007 08:04 AM
"Power Tracking" in supply, ever heard, DIY ideas? Cradle22 Solid State 19 4th June 2003 09:02 AM
Copyright 1999-2017 diyAudio
