12" J-bin.... 12" J-bin.... - diyAudio
12" J-bin....
12" J-bin....
Old 24th February 2008, 04:25 PM   #1
Empee is offline Empee  Netherlands
Empee's Avatar
Default 12" J-bin....
Hi !
I know there's been some talking about this but I
cannot seem to find any workable conclusions...
So my question is;
Can a J-bin / Scoop as used in PA, be made with a 12" driver ?
Off coarse it can, but will it work ?
Now I'm posting this in the Fullrange-forum, as I intend to make
a hifi-sorta scoop using the ol' Philips AD12202.
A terrific fullrange 12" although I'm a little worried of the high-ish
total Q (being somewhere in the range of 1.2 I guess)
My thoughts are as follows;
If I were to scale down the original J-bin, I'd alter the hornlength,
pushing the lower horn cut off frequency up.
But isn't it smarter to just narrow the design,
so keeping the hornlength the same ?
And if this is a way to go, how much would it be narrower ?
Maybe some of you backloaded-horn-masters can help me with
this please ?
Empee
In the end, all is good
If it's not good, it's not the end
Old 24th February 2008, 04:53 PM   #2
GM is online now GM  United States
GM's Avatar
As Qts increases, so goes the filter chamber (Vr) and throat area (St), changing the horn profile, ergo horn size increases.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 24th February 2008, 07:36 PM   #3
Empee's Avatar
hi GM,
That's usefull information!
So I get to learn something on a sundaynight :-)
But is a Qts of 1.2 any good for hornloading ?
what be your cabinet of choice for these 12" Philips drivers ?
Empee
Old 24th February 2008, 08:26 PM   #4
GM's Avatar
Greets!
Well, it would depend on the rest of the driver specs and what the performance goals are, but as a general rule a ~0.707 Qts is the upper limit.
If the Qts is this high, then either OB or a max flat impedance TL, but the latter requires specs to calculate it.
GM
Old 25th February 2008, 07:04 AM   #5
Empee's Avatar
Hi!
found in another thread:
Originally posted by edlye
I just found a spec sheet, but it is in German: http://www.rahaso.de/foren/msg.php?f...nge&idx=18657&
Here's a translation with the help of babel fish:
nominal impedance 8ohms
d.c. resistance of the moving coil 6.6ohms
load rating 100W
max load 150W
output 0.5W
resonant frequency 45Hz
through howling tension (lost in translation?) 9V
transmission range 50Hz - 19kHz
magnet material FXD
magnet diameter 124.6mm
magnet mass 990g
energy in the air gap 498mWs
magn. flow density 1110mT
air gap height 8mm
height of the moving coil 9.7mm
minor diameter 35mm
basket diameter 313.3mm
sound opening/free space 278/5mm
depth 135mm
mass of the loudspeaker 1650g
Unfortunatly, no Qts....
Can it be derived from other numbers ?
Empee
Old 25th February 2008, 07:45 PM   #6
GM's Avatar
No, it's like figuring out how fast your car will do 0-60 from how much your motor weighs and the size of the transmission's gears. We did learn Fs = 45 Hz, Re = 6.6 ohms and a minuscule 0.85 mm Xmax though.
GM
Old 26th February 2008, 07:34 AM   #7
Empee's Avatar
Hi !
hmmm, ok, I get your point
Seems there is no alternative then to try to measure Qts myself
Do you have any methods you'd like to recommend ?
I got some more speakers I'd like to measure so it would make
a nice session. Next weekend I'll have the time to do this...
By the way;
the "recomended enclosure" by Philips is "bassreflex or hornloading",
so I guess Qts isn't that high afterall...
Empee
Old 26th February 2008, 09:10 AM   #8
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
http://sound.westhost.com/tsp.htm
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 12th March 2008, 02:03 PM   #9
Empee's Avatar
Default finally !
I got all specs' !
Qts is 0,8, wich is a wee bit too high for hornloading...
Would a BVR (yet another son of Chang) be a good way to go ?
Empee
Old 12th March 2008, 02:16 PM   #10
rcavictim is offline rcavictim  Canada
rcavictim's Avatar
Default Re: finally !
Originally posted by Empee
I got all specs' !
Empee
That chart is unreadable.
"There are more worlds than the one you can hold in your hand." Albert Hosteen, Navajo spiritual elder and code-breaker, X-Files TV Series.
12" J-bin....Hide this!Advertise here!
What Does Fostex "Rated Input" and "Music Power" mark02131 Full Range 5 13th October 2012 05:18 AM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Charcoal "Supreem" hi-density foam "enclosure" IG81 Multi-Way 0 23rd April 2009 01:34 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Copyright ©1999-2017 diyAudio
