Hi!
How could we calculate-model-simulate a BLH, where the mouth is located (opened) to the floor?? I know in this situation the floor and the side wall and back wall, these junctions become part of the mouth, but I don't know how big is this influence for the "classic" way calculated horn lenght and size. How could I calculate such a horn with MJK's program? Greets: Tyimo |
#2 |
If it were sitting on a floor with no nearby walls, it would be radiating into half-space. This can be calulated in Hornresp, not sure about MJKs sheets.
#3 |
Remember though, if it is firing straight at the floor, you will run in to reflected waves running back up the horn. NOT GOOD. This will cause smear and cancellation like you have never thought possible. Firing at the floor seems like it won't be a good idea, period. Why would you want to fire at the floor anyway? Just curious.
Tom |
#5 |
With the internal deflector in place its not firing at the floor but produces a 360 degree radiation pattern.
ron |
#6 | |
Yes, theoretically you "could" have true, but in the reality it works very well! Listen to the Impulse loudspeakers! Ron has true: with (and without!) the internal deflector in place its not firing at the floor but produces a 360 degree radiation pattern. You could imagine like the hornmouth is located near the floor and opened along the 4 sides of the cabinet. I wouldn't like to open a discourse about why is it good or not, rather I would like to concentrate for the calculating-modeling solutions. Tyimo |
#7 |
The bottom-firing horn, a technique elegantly deployed by among others Dr. Bruce Edgar in his "Monolith Horn". This is potentially a very effective approach, in that it wraps the mouth around two or more sides of the cabinet. For the bottom-firing horn, we can easily obtain a very large mouth opening by wrapping the mouth around four sides (both sides and front and rear), and mounting the horn on stands of appropriate height. We'd need stands of just enough cm height to obtain the same mouth area.
Greets: Tyimo |
#8 |
Dave?!?
Scott?!? Martin?!? |
#9 |
I'd just model it in MJKs BLH Sections sheet or hornresp as best you can. Job's a good 'un (or as close as you're likely to get).
| Horn mouth bubble size | MaVo | Subwoofers | 1 | 25th February 2009 11:59 AM |
| Horn Mouth Diffraction | mefistofelez | Multi-Way | 11 | 14th October 2005 01:04 AM |
| rear horn mouth area | big_kahunah | Full Range | 1 | 16th August 2005 01:35 AM |
| Screen in horn mouth? | Stocker | Multi-Way | 7 | 9th March 2005 09:39 AM |
| Horn speaker w/variable throat & mouth | bbaker6212 | Multi-Way | 1 | 1st August 2003 07:27 AM |
| Page generated in 0.11744 seconds (76.34% PHP - 23.66% MySQL) with 11 queries |
