Old 21st February 2008, 04:14 AM   #1
audiophile36's Avatar
Default Full ranger and a woofer question
Is there any problem with running a 12" woofer wide open to an Fostex Fe126e.The woofer will be in a BR box and the Fostex Fe126e will be mounted on top of the woofer box in an open baffle...do I need a crossover?
If it sounds good it is good!
Old 21st February 2008, 05:51 AM   #2
frugal-phile(tm)
planet10's Avatar
An XO will be needed to get the most out of them
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st February 2008, 05:57 AM   #3
Thank's Dave,
What kind of crossover should I use...I want to keep the Fe126e crossoverless?
Old 21st February 2008, 07:35 AM   #4
hm is offline hm  Europe
hm's Avatar
Hello,
look the xmax of the Fostex,
try a closed box and cut 6dB ~300-400 Hz,
i donīt think an OB is a good idea for the 126.
If you take two of them you can build a horn
and you donīt need a bass.
Look my KORNETT
http://www.hm-moreart.de
Old 21st February 2008, 08:56 AM   #5
Scottmoose's Avatar
It'll depend on the woofer you select. You should be able to leave the 126 alone & let the woofer handle the LF to an extent, although it's not ideal.
FWIW, I'd do roughly what Martin does on his 2 way OBs; simple 2nd order circuit; high pass the 126 at 500Hz & low pass the woofer at 200Hz, both of which are typically good points to place an XO.
Old 21st February 2008, 10:40 AM   #6
Originally posted by audiophile36
Thank's Dave,
Have you considered bi-amping? One of my systems is a similar setup (FE167E, though), with 4th order active Linkwitz-Riley crossovers before the amplifiers. Bi-amping is more expensive and complex, but does have many benefits - you should seriously consider going this way.
If you don't want to biamp, then I think hm is right - you should consider putting the fostex in a small sealed box to roll it off, and cross the woofer in at the right frequency. Getting the phase and crossover curves right for such a setup will require some careful design.
Old 21st February 2008, 03:40 PM   #7
Scottmoose's Avatar
It occured to me earlier, why a BR for the woofer? If you don't have the drivers already, I'd probably just go for Martin's 2 way (well, FR + woodfer) OB, or a variation on that. It won't lack for LF output, and the Eminence Alpha 15 isn't a pricey unit.
Old 21st February 2008, 08:31 PM   #8
I want to go all OB but don't know how to cut holes larger than 6" because they don't make hole cutters larger than 6". I have a jig saw,but I don't know how to start a cut when trying to cut out a circle.
Old 21st February 2008, 10:06 PM   #9
Scottmoose's Avatar
Wouldn't that affect a 12in woofer in a box too?
I'm about the last person to ask in-re woodwork, but there are plenty of knowledgeable people here who'll be able to help you out. Make or buy a circular jig for your router would be favourite I imagine.
Old 21st February 2008, 10:11 PM   #10
germpod is offline germpod  United States
My driver holes are not perfect, but I just drill a hole on inside of the circle so the jig saw blade can get in and cut from there.
Fostex full-ranger for in wall use :-) sharpi31 Full Range 4 5th March 2008 10:46 AM
not really a full ranger Nanook Full Range 3 3rd April 2006 08:20 PM
Which full ranger for 3L sealed? noobsta Full Range 3 20th January 2006 12:37 PM
adding a woofer driver to a full ranger paba Full Range 7 21st April 2005 06:55 AM
Beyma 5MP60/N as a full ranger? Elias Full Range 2 25th November 2004 11:37 AM
Page generated in 0.12853 seconds (66.30% PHP - 33.70% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
