I've bought Bob's plans and have ordered parts. Nice complete package BTW for anyone considering it.
Being this would be my first build...I'm not sure if I'm competent enough to do the veneering required to make them look as nice as he does. I'm thinking of building them with decent grade plywood and the hardibacker instead of MDF and staining the plywood. I would get solid Oak for a full front baffle. Anybody build his plans using ply instead of MDF? How do they sound? Thanks |
#2 |
Not that I have an answer to your question but if building out of plywood is not an option, what other options for the mdf enclosures could one use other than veneer? I am thinking of building these speakers and was looking at different coatings or textures to apply rather than just plain old gloss paint.
#3 |
The MDF/HardiBacker sandwich is a design feature of the FT-1600, and all of my floorstanders for that matter. However, there is no reason that you can't use Baltic Birch or Appleply. The thing is, I haven't done any experimenting with plywood, so I don't know if you will get any objectionable ringing. My guess is that with the Hardibacker glued down with Liquid Nails, probably not.
If you do not veneer the cabinet with a single piece of veneer as per instructions, you will need to solve the problem of what to do with the raw edge of the MDF/plywood/whatever. The craftsman approach is to use pre-veneered sheet goods -- both MDF and decent cabinet grade plywood should be available in larger markets, and then glue a matching strip of wood to the edge of the front panel. You can then do the round-over on the wood strip. It does take a bit of skill to make the joints between the wood strip and the sheet goods without objectionable gaps. Painting is always an option, but it takes more time and effort to do a decent paint job then it does to veneer. That's why I don't offer a paint finish. I can't afford the time at my price point. Also, if you are considering a piano finish, remember you will need commercial grade spray equipment and a dedicated spray booth. You can't do a piano finish out of a rattle can. Bob |
#4 |
I will never forget my efforts to get a piano black finish many years ago. I primed the boxes white, put my first coat of black spray, then another a few hours later... than another few coats the next day... then the next... next... next... the paint began to build up and look terrible. There were always dull spots. Eventually, i threw the cabinets away. Now i just use black wood paint from home depot and my cabinets look black and shiny but not like a piano finish. Godzilla |
#5 |
FWIW, my own FE167E MLTLs, which are quite similar to Bob's FT1600s in several areas, are built from BB ply. It's just a case of working with your chosen material.
BB plywood is considerably stiffer than MDF, and while it resonates, this tends to be at a frequency above the main passband of the cabinet. So, when working with it, the object is to keep those resonances up high, above the point where they'd be an issue. Basically, this is the opposite approach to using the denser, but less-stiff MDF, where you're looking to push panel resonance down, below the passband of the cabinet. Both methods have their advantages; my preference is for the former approach, while I know Bob favours the latter. IMO, neither is really 'better' -they're just different & which you favour is about personal preference rather than superiority. I've got two left thumbs on a good day, and no facilities at all, so my mate Ed very kindly built my enclosures (because I wanted a pair of attractive cabinets for a change, and he's a bit handy at the old woodworking) -they're in the picture below, sans drivers, next to his own Vofo folded TQWTs. In construction terms, the front-panel is doubled, all vertical panels are end lap jointed (I believe that's the correct term), leaving only a 5mm vertical band of exposed ply edge down the back of the enclosure. The front & upper ply edges are concealed by 3/4in pine quadrants. Panel resonance is a non-issue -the ply isn't adding anything of its own to the proceedings. |
#6 |
Yes. This is exactly the technique I was recommending if you want to use pre-veneered flat goods. Remember, though, if you choose a dark stain rather than just a clear finish, the wood strips must be the same species as the panels or the color will not match.
Bob |
#7 |
Yeah, works a charm, but takes a bit of practice & you have to be very careful with the measuring, as you mentioned. The dark lines between birch & pine on mine are primarily cosmetic, but also erradicate any potential gap problems.
#8 |
Scottmoose, those boxes look great!
Godzilla |
#9 | |
So you just turn that into a "detail feature" Very pretty boxes Scott - kudos to Ed
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#10 |
Thanks all...
I have been giving alot of thought to how edge will look and how stain will take. Bob, If I replace your baffle with a piece of solid wood that was cut 1 1/2" wider , I could cover that raw edge. And, you're right about the stain, would be difficult to get a match if material is different. I got speakers in last night and rest of parts will be here today, so I need to get on it. Like most newbs, I have been suffering from info overload. Took a couple weeks of reading and searching and I have least figured out what I want to build and where I will place them. I have always heard that "procrastination is the key to flexibility" but at some point you just have to do it and see how they turn out. |
| OSB vs Plywood | Chris8sirhC | Multi-Way | 34 | 8th August 2008 07:05 PM |
| Using a hi-vi rt8-2 tweeter with Bob Brines Ft1600 MKII | Petey | Full Range | 1 | 24th December 2007 11:38 AM |
| Pinoy DiY'ers, FT1600 pics..pics | dranreb&* | Full Range | 5 | 3rd November 2004 10:21 PM |
| plywood instead of MDF? | jdeare | Multi-Way | 2 | 21st February 2003 12:36 PM |
| Page generated in 0.12252 seconds (77.17% PHP - 22.83% MySQL) with 11 queries |
