diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   Foster FE103A (http://www.diyaudio.com/forums/full-range/117482-foster-fe103a.html)
rca9449 15th February 2008 06:15 AM
Foster FE103A
Does anyone know what's the specs for the vintage Alnico Foster FE103A. I have a pair coming and just wondering if they would be usable with a 3/4 watt single ended darling amp.
Also, has anyone try them on open baffle with a low frequency helper - something similar to this: http://www.quarter-wave.com/OBs/OB_Design.pdf
I plan to copy this design except running the FE103A without any crossover.
Thanks in advance.
planet10 15th February 2008 06:45 AM
Actual T/S will vary from unit to unit.
Fs from 85 to 150, efficiency from 89-92 dB.
When you get them please post pics. I have had quite a few of these, some need some attention before use.
dave
Piek 15th February 2008 09:22 AM
Hi, here is the response of the Sigma (red line), if this is comparable...
FE103Sigma
-Micha
rca9449 15th February 2008 12:11 PM
I will post pictures when they got here Dave. By the way, have you ever used two of them in parallel per cabinet - I can use the 6db efficient bump - wonder if that will mess/smear up the wonderful midrange.
Thanks for the link Micha. I will check it out.
Scottmoose 15th February 2008 04:49 PM
If you had them on the same baffle, it will destroy the mids + treble. Not recommended. If you must, bipole or possibly one on the top (though there's an increased risk of damage) will give a semi-omni effect & not cause the same lobing issues you'd otherwise run into.
badman 15th February 2008 05:19 PM
Minor Nitpick
3 dB efficiency bump, 6dB sensitivity bump.
rca9449 15th February 2008 06:06 PM
thanks badman - that's what i meant.
that's what i thought Scott. i will just use one. thanks.
planet10 15th February 2008 06:13 PM
We had 2 pair of these in BD-Pipes. They worked well.
dave
rca9449 7th March 2008 04:04 PM
Pictures
2 Attachment(s)
They finally arrived. Pictures enclosed as promised Dave.
They are different - can't really use them. Perhaps someone has an odd ball that they want to trade. I really want to use that alnico magnet.
rca9449 7th March 2008 04:05 PM
2nd pict
2 Attachment(s)
Copyright 1999-2017 diyAudio
