Old 13th February 2008, 08:47 PM   #1
odell is offline odell  United Kingdom
Default Designing for corner placement
I'm looking for some help - I have a pair of Fostex FE167E drivers which I plan to use in a small room (6' 3" x 9' 2" with 8' ceiling). The resulting speakers will need to be mounted on the short wall (over a desk so floorstanders are out) and I will be listening from around 2-3 feet. Amp is a Trends TA 10.1.
What I would ideally like to do is build cabinets with a triangular cross section which would then fit flush into the corners. What I don't know is how to adapt the cabinet design to work with the corner placement rather than against it. Should I go for a 15l cabinet as recommended by Fostex or something a little larger? How can I avoid boomy bass or other problems normally associated with corner placement?
Thanks for your help,
Mark
Old 13th February 2008, 10:45 PM   #2
John L is offline John L  United States
John L's Avatar
Are you living in prison?
Old 13th February 2008, 11:03 PM   #3
Godzilla's Avatar
http://www.zillaspeak.com/systems.asp
http://www.zillaspeak.com/bib.asp
My room is not much bigger.
Godzilla
Old 13th February 2008, 11:57 PM   #4
ttan98 is offline ttan98  Australia
Default Re: Designing for corner placement
Mark
try this site you may get a few ideas there.
http://www.pispeakers.com/
the designer/owner is very helpful.
Old 14th February 2008, 12:34 AM   #5
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
Boomy bass is better than no bass
In all honesty I've had some full rangers sound better in the corner. The bass was slighly boomy but still better defined then what comes out of a lot of the subs these days. The FE167E normally has no bass anyways without a BSC circuit. So the recommended enclosure adapted for the corner might do fine with no correction circuit.
Corner horns are sweet. There is one using the FE167E on the Decware website, but it's big and heavy.
Old 14th February 2008, 03:33 AM   #6
frugal-phile(tm)
planet10's Avatar
Maybe in your experience. Unless in a big room we found Demetri to have too much bass, Also keep in mind that pushed up against a wall a box has next to no baffle step. In a corner, and in a room this small, you want to design for very low Q bass if you don't want it to be boosted. I'd start out with a sealed box with Q somewhere between 0.5 & 0.577.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th February 2008, 04:24 AM   #7
Jeb-D.'s Avatar
What is Demetri? I've only run the FE167E driver in the recommended bass reflex, which may be the reason for lacking bass. Excellent sounding with a BSC circuit, but very harsh and shouty without one. It also does pretty good without BSC compensation, when driven by an amp with a Zout of 8ohms and a Zobel.
Old 14th February 2008, 06:34 AM   #8
frugal-phile(tm)
planet10's Avatar
Quite a bit bigger than the 167 BR
http://www.planet10-hifi.com/boxes-fostex.html
We built a variation on the factory 15l (with lower tuning) for our initial 167e tweaking experiments.. It was good sounding and served th epurpose -- low bass is not its strong point -- and the current owner really enjoys them.
dave
Old 14th February 2008, 10:14 AM   #9
Scottmoose's Avatar
Yeah, the Fostex BR isn't bad -one of their better reflex-boxes IMO, but it doesn't extract the most out of the drivers; certainly not WRT extension.
My own 167 MLTLs are actually running sans a BSC circuit too. That said, they are pushed up against a rear wall, which helps, despite my designing them with as narrow a baffle as possible.
Old 14th February 2008, 12:35 PM   #10
Thank you to everyone for the replies - I'm new to this and you've been very helpful.
I don't expect miracles from this compromised room, but would like to make the best out of the situation. As far as bass goes my only reference is listening to typical small standmount speakers which list frequency reponse low numbers of around 65/70Hz. I wouldn't want less bass than this type of speaker.
I've plotted a couple of boxes in WinISD - a 15l sealed box gives a Q of 0.57, as advised by planet10. Am I right in saying that I could start sealed and simply add a port later if necessary?
Also, should I build the triangular cross section cabinet with a narrow baffle (equilateral triangle) or a wider baffle (right triangle) - what affect does baffle width have?
Thanks again,
Mark
Designing for on-wall/near-wall speaker placement morbo Multi-Way 4 27th November 2010 04:52 PM
Pros and cons of corner placement nunayafb Multi-Way 9 5th May 2006 09:08 AM
sub for corner placement... wuffer Subwoofers 5 23rd December 2005 09:23 AM
Line array behavior with corner placement johninCR Multi-Way 8 19th August 2005 02:52 PM
Designing for guys who like designing Sch3mat1c Tubes / Valves 14 31st August 2003 11:46 AM
Page generated in 0.12291 seconds (78.46% PHP - 21.54% MySQL) with 11 queries
