2-3 inch driver to suit my needs?
Old 1st February 2008, 05:41 PM   #1
Fast1one is offline Fast1one  United States
Default 2-3 inch driver to suit my needs?
I am looking for a driver for a car audio application. It will be run full range, or with a helper tweeter if needed....I was hoping people can give my some insight on what to get, if you have heard the specific drivers I am going to mention, or have any others that meet my criteria , please post your comments!
This is what I need/have:
Power: ~20-35 watts at 8 ohms, 75 at 4, 110 at 2...
Crossover: 12-18db high pass at ~3-400hz
Sonic needs: I want the driver to be as detailed as possible, but the most important thing to me is how "listenable" the driver is for extended periods of time...In other words, I want a driver that is detailed, but very laid back and non-fatiguing (little/no shouting) like the Pioneer BOFU in my home...
Impedance/sensitivity: This is obviously a big issue as it is a car audio amp that does rated power at lower impedance loads, so if it is an 8 ohm driver, I would imagine it needs to be at the very least 85+ db efficient, Fostex drivers win this area with flying colors, something like the Hi-Vi B3S probably won't be loud enough for my tastes...
Budget: I would prefer to spend around 30-40 shipped for the pair (10-15 a driver). However, if it is worth the price, I would be willing to spend as much as 30 dollars a driver...
Whew! Now on to the drivers I have selected, Again, if you have any other suggestions from other vendors, please feel free to post them:
FF85K
http://www.madisound.com/catalog/pro...roducts_id=281
FE87E
http://www.madisound.com/catalog/pro...roducts_id=277
Pearless 2 inch
http://www.madisound.com/catalog/pro...oducts_id=8267
Tang band 2 inch
http://www.partsexpress.com/pe/showd...number=264-805
The famous Tang Band 3
http://www.partsexpress.com/pe/showd...number=264-813
Finally the Bamboo 3, which is very intriguing...
http://www.partsexpress.com/pe/showd...number=264-844
Thanks for all the help ahead of time!
Serg
Old 3rd February 2008, 11:26 PM   #2
Anyone? I am leaning towards the W3-871...
Old 4th February 2008, 01:39 AM   #3
loninappleton is offline loninappleton  United States
For 2's and 3's also consider the Aura Sound items parts.
For real sound go to a 4 in if you mount em someplace.
After experimenting with the TB 871's they have to be pushed too hard for my tastes. Many car installations have coaxials which contain 2 drivers, one mounted inside the other. And car audio designed for car
tuners and amps should provide a good selection.
Check Parts Express auto sound section.
Old 4th February 2008, 02:35 AM   #4
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
The 1st FF85Ks we had were even better than we were hoping. Just ordered more so i could see how well they do before modification.
I've had W3-871 there was always something about them that bothered me. THe Aura B3 is better but not very efficent.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th February 2008, 03:34 AM   #5
Did you experiment in a car environment? Keep in mind the space is very small, so 20-30 watts will be more than enough to make my ears bleed (I have closer to 30-40 watts most likely)....
dave
I do not have much experience to begin with, so honestly if its something really small that only an experienced audiophile can detect, I probably won't notice it. Keep in mind I am only spending 20-30 dollars per driver, so this obviously isn't an ultra high quality install...
If you can comment on how fatiguing (or not) the driver is (both the tang band and the fostex), that would be really helpful...
Old 4th February 2008, 03:46 AM   #6
frugal-phile(tm)
planet10's Avatar
On other drivers the treatment on the FF85k fights fatigue so i can only comment on the treated driver -- very fatigue free. I couldn't listen to the 871 for long.
dave
Old 4th February 2008, 03:52 AM   #7
AdamThorne is offline AdamThorne  United States
AdamThorne's Avatar
I've got the w3-871s, they became much more laid back after I damped and reinforced the frame. I used plumbers epoxy putty on the basket / magnet junction, and rope caulk all over the place (particularly under the lip on the front flange). With the notch filter as well mine sound fairly mellow. With the frame damped I think you could get away without the notch filter, depending on your other components, but I wouldn't swear to it. The notch will drive up your driver costs, if you decide to use it...
I don't run them with a tweeter, but I've considered it.
I know my sub helped mine out a lot, so I imagine crossing as high and steep as you are talking about would give them a fairly easy job.
I sorta think any of these drivers would be nice enought that if I were driving around the road noise would be enough to mask the finer points these drivers would be able to recover. You may be more hardcore about the car stereo than I am tho.
I frequently think that my car stereo doesn't sound anywhere near as nice as my TB speakers, but that's stock for you...
Old 4th February 2008, 05:03 PM   #8
Thanks for your reply! Like you said, I figure any driver will sound pretty good in a car audio environment, especially since my car hasn't been treated with dampening mats for road noise...I think I will go with the 871 and treat the frame like you said...
Old 4th February 2008, 05:45 PM   #9
AdamThorne's Avatar
I don't want to take anything away from what Dave says, cause he sure knows his stuff. But when I hear someone say 'does anyone like the w3-871?' I have to raise my hand...
Maybe when I (finally) get my Fostex based speakers done I'll be less forgiving of the T-Bs.
Old 6th February 2008, 11:35 AM   #10
lcsaszar is offline lcsaszar  Hungary
I am very pleased with my w3-871s in a Buschhorn that has all dimensions reduced to 2/3rd of the original. They sounded a bit harsh but it could be cured by stuffing the compression chamber behind the speaker with mineral wool. Now they are very neutral. The best test I found is human voice, especially man's sound from a radio station (e.g. reading news). That reveals every coloration and unnaturalness.
2-3 inch driver to suit my needs?Hide this!Advertise here!
Ideal power level to suit a driver? Pbassred Multi-Way 0 27th April 2009 03:27 PM
L-pad attenuator for midrange driver 6 1/4 inch driver rhythmdiy Multi-Way 0 4th November 2007 03:32 PM
Base driver to suit ESS Heil driver gerado Planars & Exotics 6 1st August 2007 07:56 PM
18 inch Pro Driver Ricky Multi-Way 0 21st July 2007 03:11 PM
Best 6 1/2 Inch Driver Under $100 peteboyer Multi-Way 4 26th October 2001 06:57 PM
Copyright ©1999-2017 diyAudio
