Fonken floorstander MKII - Page 2 - diyAudio
Old 15th January 2008, 06:37 PM   #11
gurley123's Avatar
originally posted by Badwater
I use kitty litter. Cheap and easy to use.
Funny thing is, my cat uses it too.
Old 21st January 2008, 03:28 AM   #12
ecir38 is offline ecir38  United States
ecir38's Avatar
I end up using kitty litter and a jar of bb's from walmart. One half of the jar per enclosure was more than enough weight.
I still plan to use a 3/4 roundover on the baffle unless instructed otherwise. Pics to come soon.
Old 21st January 2008, 03:45 AM   #13
renfrow is offline renfrow  United States
renfrow's Avatar
The only thing I'd worry about, with kitty litter, is the possibility of it absorbing moisture over the years and expanding. Given that, aquarium sand looks like the safer alternative.
Tom.
Now, we can do this the hard way, or... well, actually there's just the hard way.
-- Buffy Summers (Buffy the Vampire Slayer)
Old 21st January 2008, 06:06 AM   #14
frugal-phile(tm)
planet10's Avatar
Originally posted by ecir38
I still plan to use a 3/4 roundover on the baffle unless instructed otherwise. Pics to come soon. [/B]
some roundover is better than none. A champher is just as effective.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st January 2008, 09:19 PM   #15
ecir38's Avatar
I just fired these up, all I can say is WOW!!!! I am a believer. I integrated them with a sub and it was truly amazing. Can't believe this 4.5" driver is doing what it is and this is at a zero hours on the driver, can't wait to get some hours on them.
I left the poly fill out of one of them but did not pay attention to which one it was. One speaker defiantly sounds fuller than the other, I will know which one it is when I disassemble them for finishing. I just have to install the bases I made with spikes and then can start finishing. Hope to have some pics in a couple of days.
Thank you for the FONKEN!!!! Now I know I am going to want to build something with the bigger drivers .
Old 21st January 2008, 11:11 PM   #16
frugal-phile(tm)
planet10's Avatar
The bigger drivers won't necessarily sound better... i have ordered drivers to start R&D on an uberFonken thou.
dave
Old 22nd January 2008, 04:38 PM   #17
gurley123's Avatar
Default C'mon, let's see them.
Any pics of the finnished product or are you too busy listening?
Old 22nd January 2008, 06:39 PM   #18
ecir38's Avatar
Default Re: C'mon, let's see them.
Finished pics at the earliest will be Thursday.
Old 23rd January 2008, 01:22 AM   #19
ecir38's Avatar
Dave which drivers will you be working with for the uberFonken? Or will this be the FE127 in a more effiencent enclosure? Any prelim attachments?
Old 23rd January 2008, 02:00 AM   #20
frugal-phile(tm)
planet10's Avatar
Both the FX120 & the F120A have specs that are similar to the FE127. Next i have FX120 coming (F120A still out of reach). I'll have to come up with another name too, either for between the uber & the Fonken, or some name that indicates better than uber.... Bud was quite stoked about the F120A, and Gio about the FX120.
dave
Fonken Floorstander m4rs Full Range 6 18th March 2009 01:19 PM
Fonken floorstander duct seal & damping artfuldodger Full Range 5 17th December 2008 04:14 PM
Fostex FE127eN / Fonken Floorstander Mk II Questions N1ESE Full Range 3 15th November 2008 11:36 PM
1st timer building Fonken Floorstander MkII with Planet 10 FE127eN drivers rbclark Full Range 33 24th April 2008 08:25 AM
Copyright 1999-2017 diyAudio
