Am I just being goofy in thinking this will work?
If one was to take this sub http://www.partsexpress.com/pe/showd...number=295-470 and but it in a 10 cubic foot box, it will hit around 23-25 Hz with a 4 ohm resistor in series with the driver. Because it is a 4 ohm driver with 4 ohms in series, it would be effectively an 8 ohm driver. A FR125 could be built into this box and put in parallel with the 15 inch sub with appropriate crossovers. Then the system would hit around 23-20kHz. Is this just foolishness on my part or do you think it is doable? |
#2 |
Speakerholic
Hello David,
I'm not sure why you would want a series resistor on a woofer. That's not a common practice. What is your idea there? The FR's will require a separate chamber from the main woofer. The FR driver is very inefficient so you will likely want 4 per box to keep up to the woofer. A single driver will run out of gas long before the woofer. You might wish to consider using a plate amp and using the high level outs for the FR's. That will mean using the high level ins. It will give you better overall control of the system and save money on XO's. |
#3 |
Ditto what Cal says. Additionally, if you are set on this design, at least use a series passive crossover to mate the 4 and 8 ohm drivers. That is much more efficient than just throwing heat away in a series resistor just so you can use a parallel crossover.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#4 |
Thanks for the comments guys.
The series resistor would effect the Qt of the system, pushing the response of the woofer in the low end down from ~40 Hz in the sealed box to ~23 Hz in the same sized box. This would also reduce the SPL making it easier to match to the FR125 as well as allow a parallel crossover arrangement between the two speakers. |
#5 |
As Cal suggest maybe a sub with a plate amp? I've been looking at building something similar. 12" sub + plate amp per side with an OB full-ranger (+ super tweet if needed). Use the internal (low level) crossover on the sub amp. That way the FR125 need not even try to produce any bass below the crossover point and freeing up your amplifier for the mid and high range.
Happy New Year leadbelly, haven't seen you around here for a bit. stew
stew ☮ -"A sane man in an insane world appears insane." |
#6 |
You may consider this nice 10" AurumCantus...might mate nicely
http://www.partsexpress.com/pe/showd...number=296-430 or even the Dayton 15" IB in a dipole http://www.partsexpress.com/pe/showd...number=295-455 There are a couple of problems with "your" Dayton 15" Ragged top Too efficient(?) Peaked midbass What you need is BSC, hence a higher xo point around 300hz Fore that you need a woofer with smooth FR Bass will probably need to be exstremely tight, not to "overfloat" the delicate FR125 I suppose you may get a decent result with even a simple "6db" filter But as Cal said, you wont be able to play insanely loud with the FR125...not his words, but something like that I dont know, but it might help a lot when FR125 is relieved of its bass duties |
#7 | |
| 2 inch Peerless vs 2 inch HiVi Research | richie00boy | Multi-Way | 18 | 5th December 2007 07:31 PM |
| WTB: CSS FR125's | Glowbug | Swap Meet | 0 | 13th June 2007 07:05 AM |
| Passive Radiator system with 2x10 inch and 1x15 inch | Lach O'Sullivan | Multi-Way | 3 | 13th September 2003 03:29 PM |
