#11 |
Mark,
Why did you decide to use the Beta this time instead of continuing with the Alpha? |
#12 | |
It's all about BW and acoustic efficiency. The CVs went lower with much greater acoustic efficiency. While our on-board computer apparently can reconstruct missing sub-harmonics, fundamentals from its harmonics, it's no substitute for the 'real deal' and the mids/HF sound more 'full'/extended when the missing tonally balanced LF BW is added even though there's no measurable difference in the mids/HF. As acoustic efficiency rises, distortion for a given average/peak SPL falls and at some point the mids, tweeters are no longer pushed into any audible non-linearities and the top end opens up with more 'air' around the instruments with the only way to improve it at this point AFAIK is to increase the HF BW up to the 40+ kHz of some instrument's harmonics. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#13 |
Just to chime in: There's also the issue of directionality - larger drivers "beam" more, with a smaller sweet spot.
#14 |
Yes, this falls under the acoustic efficiency part.
#15 |
Mark, Why did you decide to use the Beta this time instead of continuing with the Alpha? Actually I didn't. I quite like the Alpha's. It may have been Dave... Rgds Mark |
#16 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Sub: 1 large or 2 small drivers ? | Bigun | Subwoofers | 52 | 21st February 2009 10:46 PM |
| Multiple small drivers for large output? | diarav | Multi-Way | 15 | 29th October 2006 08:39 AM |
| Large Driver or Multiple Small Drivers ??? | emailtim | Subwoofers | 8 | 25th March 2006 10:02 PM |
| Using those small Creative titanium drivers (large pics) | Otherwise | Full Range | 1 | 2nd December 2005 08:13 PM |
| tradeoffs in small vs. large drivers | jdybnis | Subwoofers | 6 | 10th November 2004 12:24 AM |
| Page generated in 0.09103 seconds (66.12% PHP - 33.88% MySQL) with 11 queries |
