i want to built cabinets for my new super 12 Audio Nirvana.
help me for the size please. Open baffle or bass reflex ? 14" x 14" x 48 " too small ? 15" x 25 " x 48" OK excuse my bad english Claude |
#2 |
They need gigantic cabinets for BR use, so I'd be inclined to stick them on large baffles. To be honest, I haven't yet worked out exactly what this driver is for.
#3 |
These things look like large, pricey versions of Pioneer B20s. Other than having obvious differences like cone size, factory phase plug, etc. They spec very similarly to the B20s. With some flexible digital EQ, I've been able to get the B20s to do an unreasonable facsimile of true full range, even on a very small baffle (too small to physically mount the Super12, actually). Figure on a good sized baffle with good EQ, you'll probably be able to run these without tweeter or bass augmentation as long as you're not looking for reference levels or bass below 40Hz.
I actually live about 15 minutes from Common Sense Audio. If I had a real budget for this hobby, I probably would have already tried this myself. Scott, Wouldn't these work okay in some sort of TL or MLTL? Those cabinets in Claude's picture look like MLTLs, not BR. Kensai |
#4 |
I agree with Scottmoose. You need pretty big boxes to run these sealed or vented. They have a large Vas, requiring a large box and a small Xmax, limiting their lower frequency power.
Now for open baffle, if you stuck them in a JE Labs ob (http://members.myactv.net/~je2a3/open.htm), you might get some where. You should be able to put a bit of resistance in series with it as well to increase Qt and get a little more bass out of it in the open baffle. Simple to build and may sound really good. Again there is not much Xmax there which is known to be one thing that is required to get loud powerful bass. But at lower volumes it wouldn't matter much. |
#5 |
Right. A box is going to be big by modern standards. Very big.
Like this kind of big: 1 MLTL for the AN Super12. 56in x 20in x 14.5in (HxWxD). Zdriver 23in. Vent 4in diameter, 0.75in long, as close to the base as possible. I rolled it off at the bottom, if you want max-flat, increase the vent diameter to 5in. Minimal damping needed -line the box with 1in acoustic fiberglass on opposite faces. Volume for this thing is just under 9.4 cubic feet if you don't want to do the math. They're pretty sensitive, so they should do OK for nearfield listening on a couple of watts before they breach Xmax. Most people can't live with a pair of cabinets of this size these days (they were more common in the 1950s - '60s than they are today), so a baffle will probably still end up as your best bet. |
#6 |
breaking-in super 12 in open baffle 45"x24"
pleasant sound , my final choice is bass reflex.... to come later. |
#7 |
Out of interest, how do you find the HF on these things?
Bass reflex to come later? Interesting. Any clues as to the cabinet design you're going to use? Best Scott |
#8 |
out of interest ???
i will take your'e design 56"x14-1/2x20" beside , my super 8 double bass reflex. |
#9 |
Ah! Sorry about that. The BR bit threw me; the above is an MLTL, not a reflex, but I probably wasn't very clear.
#10 |
your'e right Scottmoose, my open baffle are just pieces of **** !
i destoyed them this morning . |
| audio nirvana super 10 or super 12 | tonytex | Full Range | 11 | 4th September 2011 10:55 PM |
| Nirvana super 8 and cast super 8 how do they compare to 206E? | freddi | Full Range | 4 | 22nd October 2010 02:29 AM |
| Audio Nirvana super 8 | nirvana | Full Range | 10 | 19th July 2010 10:07 AM |
| BK-16 and Audio Nirvana Super 6.5 | whitelabrat | Full Range | 6 | 12th October 2007 01:04 PM |
| LCR filters for Nirvana Super 10 - ? | freddi | Full Range | 7 | 25th August 2007 01:29 AM |
| Page generated in 0.13727 seconds (70.15% PHP - 29.85% MySQL) with 11 queries |
