Old 26th December 2007, 10:14 AM   #1
Default Fostex FP203 suitable for a sealed box?
Hi
I´m a newbee on this Forum and this is my first thread som please bare with me in case you find my question stupid
I have had two old Fostex FP203 lying around for like 10 years and now I need two fullrange speakers so I´m thinking about if the could be useful or not
The project I´m thinking about is to build two fullrange speakers for my bedroom LCD TV (37") . It´s not a surround project, just want to get a bit better stereo quality sound from the TV.
I was thinking about builing a sealed box and frankly the dimensions are more important than the sound quality (as long as the sound will be better than my original TV speakers that is..)
So my question is if the FP 203 is suitable for a sealed box construction or if I should choose another type of speaker for this project.
I realise that this could be a very complex question to answer, so I would appreciate any links you might have that could be useful for my further investigations and planning
thanks
Old 29th December 2007, 12:45 PM   #2
Sorry, but i think it's not...
Too low qts for that, a bass reflex if you would have to build a
really compact one. Othewise i would recomend my project
http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=63085
if that is too big, some sort of TL or pipe, about 1.5-2 meter
long...what dou you have for limitations in size? I think BR sound
so boooring...
Ha de gott / Petter
Old 31st December 2007, 10:31 AM   #3
so boooring...
Ha de gott / Petter
Thanks Petter!
well your project looks very interesting but for my usage as speaker solely intended for my TV it might be a bit to large (for my wifes taste that is )
Last loudspeaker boxes I built was was like 30 years ago, "RT-70/80 horn" but I remember my intentions when I bought these Fostex drivers, that I was aiming for som kind of pipe or transmission line project. Unforytunately I have no clue what I should search for regarding drawings etc, so any help would be apreciated
Do you have any suggestions on other projects? Like a 1/4-pipe, Voight or similar?
Have a Happy New Year!
Old 31st December 2007, 11:00 AM   #4
SuppersReady's Avatar
Hi joshunznera,
Seems that planet10 is the person to speak to.
A poor life this if, full of care
We have no time to stand and stare.
Old 1st January 2008, 07:16 PM   #5
frugal-phile(tm)
planet10's Avatar
Do you have any data on the FP203 -- i'm not familiar with that one.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd January 2008, 06:00 AM   #6
Hi...measured data from a friend in Sweden:
Fostex FP203
Fs 47,2261 Hz
Mmd 9,096 gram
Mms 10,722 gram
Cms 1,0592 mm/N
Rms 0,3132 kg/s
Vas 60,2 liter
Xmax 2mm
Sd 210 cm^2
Re 7,7 ohm
Le 0,155 mH
Bl 8,2979
Qms 10,1584
Qes 0,3558
Qts 0,3438
no 1,7273%
SPL 94,54 dB-2,83V/1m
good luck
Old 5th January 2008, 11:18 AM   #7
Scottmoose's Avatar
Hmm. In between latest formats & reinstalls of my PC at the moment (now on the 7th since New Year's day) so apologies if I'm only sporadically around for a while. Dead-easy solution though: using the above figures, and assuming that a horn of the more conventional sort is out for space considerations, I'd be inclined to do a nice & simple MLTL. Like this one (internal dimensions given)
54in x 9.25in x 12in (HxWxD).
Zdriver (distance of driver-centre from sealed end) = 19.875in
ZPort (distance of port-centre from sealed end) = 52in
Vent = 3in diameter x 1in long
Line the cabinet with 1in acoustic fiberglass on opposite faces (suggest top, back & one side-wall) or stuff 0.25lbs ft^3 from the top 30in down. I'd suggest 3 window-braces & a front-back brace that also clamps the rear of the driver securely to the rear panel. Birch ply prefered for the build material.
Old 5th January 2008, 11:37 AM   #8
Scottmoose's Avatar
They will also go passably into Half-Chang (or the full one for that matter): just reduce the throat length to the 3/4in thickness of the build material. http://www.frugal-horn.com/spawn-plans.html
Old 7th January 2008, 10:01 AM   #9
Rudolf is online now Rudolf  Germany
Rudolf's Avatar
I know that this Prototype that Till Roemhild did for my FP203 is quite big, but you will have a hard time getting real bass from a smaller volume box.
http://www.diyaudio.com/forums/attac...amp=1127759562
www.dipolplus.de
Fostex FP203 BL-Horn Roemhild Full Range 11 20th September 2008 10:09 PM
Fostex FP203 maal1605 Full Range 5 2nd September 2008 08:05 PM
Fostex FP203: How to tame the midrange? Keith_R Full Range 2 28th March 2006 04:32 PM
The most suitable 8" Fostex for FR horn iron Full Range 5 23rd March 2006 01:22 PM
Sealed Fostex FE126/7 a1rocketpilot Full Range 21 7th November 2005 08:33 PM
Page generated in 0.12014 seconds (73.74% PHP - 26.26% MySQL) with 11 queries
