Hi
Does any one know if there's plans to be found regarding laminating Hedlun Horns? Been searching the net, but hav not found any. appriciat any tips Best regards :-) KŒre |
#2 |
#3 |
I'm not sure about this link as it leads to a totally different speaker then the Hedlund Horns? Yes, I have noticed that these people sell the Hedlund Horns, but I was kind of thinking about making them my self... of laminated veneer, - Yes, just like the Hornet version. Hedlund's plans show how to build them from MDF, I could probably find all the measurements to make the laminating form like this: http://sparkgap.homestead.com/Hedlund.html But if the measurements are available it would be a lot easier. Does any one know if there are drawings/plans available some where? Best regards KŒre |
#4 |
The link should have read http://www.hornet.hr/Hornet.asp?sPage=Hedlund
However, if you selected the 'Hedlund' tab from the earlier link you would have got to it. |
#5 |
Those are fine looking horns. Bending thin pieces of wood would be time consuming, but it sure looks good.
#6 |
Hi
Yes, They look nice. And the bending of the veneer is something I have not tried yet. So it's got to be tried once! :-) I think that making the forms will be the most time consuming. But first thing first; to find OK measurements to make the laminating forms.... KŒre |
#7 |
It might be easier to bend the substrate first. either using kerfing, or soaking, or mutiple peices of 1/8 material, and then apply the veneer. Just a thought.
#8 |
Hi
Thanks. A friend of mine is a furniture/cabinet maker. I noticed he had some serrated MDF. really easy to bend. Can be bougt in different dimentions. My plan was to make a sandwitch construction with the MDF between the veneered layers. I think this would make the it less ressonant? KŒre |
#9 |
I'd build a pair of hedlund, using 3mm plywood laminate. Damping is never a problem, just keep add layers of ply until you are happy with the good old trusty "knocking test". mine is 8 layers.
Audio_Idiot |
#10 |
Hi
Where did you take the measurements from to make a laminating jig? Did you calculate them your self? best regards KŒre |
| Laminating cabinets | Cal Weldon | Multi-Way | 108 | 20th May 2011 03:50 AM |
| Making Hedlund Horns | ccereda | Full Range | 7 | 4th November 2007 07:51 PM |
| Hedlund horns | bnew63 | Swap Meet | 6 | 1st May 2006 08:15 AM |
| laminating glass | tade | Everything Else | 8 | 4th March 2006 07:56 PM |
| Platter Laminating...Best Adhesive? | valveitude | Analogue Source | 10 | 3rd November 2005 01:40 AM |
| Page generated in 0.09388 seconds (77.35% PHP - 22.65% MySQL) with 11 queries |
