Making Chili
Making Chili
Old 12th December 2007, 10:50 PM   #1
Secips is offline Secips  United States
Default Making Chili
Though if I find a recipe for Kimchi, I'm may reconsider.
Thoughts, suggestions, comments.
I'm using Maple Plywood 3/4 no void 10 ply. Biscuit joining all joints. The triangle at back of CC, can the slope of the triangle be arced? I can make a cove on the tablesaw. I was thinking of covering the exposed plywood edges with 1x3/4 Black Walnut. Which would mean plywood-wood-plywood joint on the corners. Good or bad? It'll be pretty. Mind you, that'll be all biscuit jointed, making the biscuits cross/interlock. Thinking of spacing them 3-4 inches apart.
Planning on cutting this weekend, if I get my tablesaw out of storage and setup.
Old 13th December 2007, 05:31 AM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Making Chili
Default Re: Making Chili
The purpose is to have an obstruction between the 2 port exits, so shape shouldn't be overly critical.
Chris built some like this... a lot of work, but gourgeous. I don't see any problems sonics wise.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th January 2008, 02:26 PM   #3
I need some help.
I've been playing around with FE167Es. To break them in I'm using a Fostex 15l VB. First impressions, for the size it has a lot of good midbass. Its very smooth, maybe too smooth. So far, so good. Images well but it seems to be lacking in the detail department.
I'm ready to put it in a Chili Chang which is the original intent. But... I'm rather concerned that the bass may become overpowering in my room. I have double thick walls/ceiling and concrete under carpet. Its a very efficient room. Its 8x13x20 closed room, I put my speakers on the short wall. I was looking at the Pawo and it may be perfect for my application as I put my speakers 4-5 ft from the back wall and
1-2 feet from the side walls. With the ports side firing into the center of the room may help with the holes there are. Right now, I don't need BSCs even with a baffle only as wide as the speaker. But the Pawo doesn't use a 167e. I was wondering, if a 167 can be put in a Pawo. Metronome or Demetri, but I plan to use this box with a Hemp FR8. Or....(drum roll) A half-Chili-Chang . GR box? Side-firing port? What do you think?
Old 12th January 2008, 03:36 PM   #4
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
I wouldn't worry about too much LF. I rolled the cabinets off slightly in the LF, & with the curved-front version, you've also got a focusing of the radiation. Besides, it's better to have too much than too little. You can always damp out what you don't need.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 12th January 2008, 04:25 PM   #5
I'll have to change recipes then. Too bad, I've got the ingredients prepared. Then again, I could always use it for something else. Where do I get the recipe? Thanks.
Sorry, to be a pest but a half chili chang maybe attractive size-wise. Sound-wise if its as punchy as the 15l VB.(I'm sure it'll much better) It could be quite popular.
Old 12th January 2008, 05:10 PM   #6
Scottmoose's Avatar
Fire an email Dave's way & he should be able to get the preliminary plans to you.
I did a single vent version some time ago -probably buried in Dave's email. We have to fit this in amongst paying work & PhD research respectively, so it takes a while for things to appear. It won't be as effective as the double-mouth version, so the latter tends to take precidence with others following.
Old 12th January 2008, 05:20 PM   #7
Just wanted to add a picture of the ingredients
Black Walnut
Chili in pieces
Old 12th January 2008, 06:01 PM   #8
Test box for the Fe167e
Old 12th January 2008, 09:55 PM   #9
Brett is offline Brett
Brett's Avatar
The thread title made me hungry. Now I'm going to have to go downstairs and make some.
Old 12th January 2008, 10:34 PM   #10
John L is offline John L  United States
John L's Avatar
chili,...............or Kimchi?
Making ChiliHide this!Advertise here!
Half Chili build hwong Full Range 40 9th January 2009 09:49 AM
Chili Chang amro Full Range 11 23rd December 2007 11:16 PM
Fe167e Hiro, Chili Chang ... Something else ? sedge1 Full Range 29 13th October 2007 08:00 AM
