Why not much on Pioneer B20 MLTL?
Old 6th December 2007, 06:44 PM   #1
davidallancole is offline davidallancole  Canada
Default Why not much on Pioneer B20 MLTL?
Why isn't there much information (or any?) on using the Pioneer B20 in a MLTL? Is everybody to busy working on the Changs? I found the money to buy some of them with the recommended tweeter and was hopeing to build a MLTL for them. Does anybody have a design for one?
Old 6th December 2007, 07:38 PM   #2
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
http://www.zillaspeak.com/pioneerb20-3cubox.asp
In reality, an MLTL with that aspect ratio. Zdriver wants to be 20.5in from the internal top (I calc. 20.43in actually -just round to the nearest sensible figure). Stuff 0.35lbs ft^3 of material from the top 27in down.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 6th December 2007, 08:13 PM   #3
Thanks Scottmoose. I will try to build that one.
Has anbody tried building it yet?
What about the slot port at the bottom, does it need to be shorter? That length is based on how it sims up as a bass reflex in WinISD and I see that the port is usually shorter in an MLTL from designs I have looked at.
Old 6th December 2007, 11:23 PM   #4
Scottmoose's Avatar
No-one's built one to the best of my knowledge, which is a pity, as it'd be well worth it IMO. Ironically enough, WinISD's prediction for a reflex is also a pretty good approximation of this MLTL, which doesn't often happen.
Old 6th December 2007, 11:30 PM   #5
Sweet, thanks Scottmoose. You are helpful as always. It will be a slow build, I need the time to go home were my dads wood shop is, but hopefully over the next few months I will have built one up.
Old 6th December 2007, 11:30 PM   #6
GM is offline GM  United States
GM's Avatar
Greets!
I posted a bunch of them some years ago on the old FR forum and AFAIK no one built any, they were more interested in putting them in little boxes, and no one's asked about them here until you AFAIK.
FWIW, here's the one I wanted built:
L = 50.75"
CSA = 127.372"^2 ( prefer 28.5" W x 4.47" D)
zdriver = 19.3"
zport = 4" dia. x 2" long near/at the bottom for T/S max flat
All dims i.d. and approximate, minimal stuffing and add more down at/in the vent if too 'boomy'. Driver mass loaded against the back panel.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 6th December 2007, 11:59 PM   #7
That looks nice GM. You would have a pretty wide, but not very deep box with that. You wouldn't necessarily need BSC with that up against the wall. I think if I have the time and money, I will try both.
This is what I am working with for a room. The pony wall is 29 inches deep and 46 inches tall. The roof is 80 inches from the floor.
Old 7th December 2007, 12:00 AM   #8
Scottmoose's Avatar
I like! Especially the minimal damping bit. And with that kind of aspect ratio, this is another 2001 style Monolith, if painted black. I didn't know you'd done those / that Greg. Loads of gain, little damping, no BSC -can't go wrong.
If you're feeling insane of course... welcome to my nightmare. I think you're g... (sorry, don't know what came over me). Something I did for fun recently: 2 B20s per channel (lower one rolled off above ~500Hz) with perfect 1:4:9 external dimensions (3/4in material assumed) 8in x 32in x 72in (DxWxH). Vent 4in diameter x 1in long, 3in up from internal bottom. See attached FR. Nobody would ever be insane enough to build a pair, but I couldn't resist it.
Name your poison, Gentlemen:
http://www.youtube.com/watch?v=wcRSwo9bGHQ
Old 7th December 2007, 12:01 AM   #9
Another shot.
Old 7th December 2007, 12:04 AM   #10
I would think the one GM has proposed would work the best in my room. You guys agree?
Why not much on Pioneer B20 MLTL?Hide this!Advertise here!
BR, TL, or MLTL? 00600 Full Range 0 26th January 2009 02:40 AM
Is this a TL/MLTL? Tuliman Multi-Way 5 15th April 2006 04:38 AM
Mltl big_kahunah Full Range 2 31st August 2005 03:40 AM
Copyright ©1999-2017 diyAudio
