New enclosure for my full rangers (Supravox 215 SB)
Old 5th December 2007, 10:53 PM   #1
Nielsio is offline Nielsio  Netherlands
Nielsio's Avatar
Default New enclosure for my full rangers (Supravox 215 SB)
Hey guys,
In my current room I don't have enough space to put huge open baffles like I could in my old room ( http://my.hifi.nl/index.php?user=1088 ).
So now I'm thinking of making a sealed enclosure or semi-open box, that can fit on my (large) desk.
These are the specs:
http://www.supravox.fr/anglais/haut_...s/215_SBIC.htm
(note the high qts)
47 Labs Hotei speakers are semi-open, I think:
http://www.sakurasystems.com/products/hotei.html
By the way, I play mine equalized (digital equalizer Behringer 8024).
Do you guys have any good ideas? I'd like to keep the size manageable but on the other hand I don't want to degrade the sound too much (obviously).
If the design works out though, I think it could be a good speaker for other people as well (in combination with the equalizer) as it's much more easier placeable compared to a humongous open baffle.
Behringer DEQ2496 . Twisted Pear Buffalo II DAC . JLTi tube buffered LM3875 . Supravox 215 Signature Bicone 125L vented
Old 6th December 2007, 04:47 PM   #2
Nielsio's Avatar
Nobody?
Old 6th December 2007, 06:45 PM   #3
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
OK you could try an aperiodic standmount. 24in x 12in x 15in (HxWxD). Driver 12in down from the top, and either two of those Scan Speak aperiodic vents on the back if you're feeling lazy or make your own. Dimensions are internal. Box is damped 0.6lbs ft^3 of material. There's a slight lift below 100Hz to add a touch of richness.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 7th December 2007, 12:37 AM   #4
Nielsio's Avatar
Thanks!
Aperiodic vent sounds hot!
http://diyaudioprojects.com/Technical/Aperiodic/
Question: what tool do you use for that graph? I used to have an online one but I lost the link.
Old 10th December 2007, 04:40 PM   #5
Nielsio's Avatar
Originally posted by Nielsio
Thanks!
Quoted for the software. Thanks.
New enclosure for my full rangers (Supravox 215 SB)Hide this!Advertise here!
French Full-rangers elac310 Full Range 15 22nd May 2009 06:27 AM
FS - 12" E-V LT-12 full-rangers dimitri Swap Meet 4 13th May 2009 09:11 PM
first set of full rangers done rtenyes Full Range 6 23rd July 2007 11:22 AM
Lines of 5.25" full rangers? Kensai Full Range 5 18th July 2006 09:03 PM
OB near full rangers... Nanook Full Range 0 20th February 2005 08:02 AM
Copyright ©1999-2017 diyAudio
