Best full range designs suited to rock music?
Old 30th November 2007, 08:13 AM   #1
wixy is offline wixy  Australia
Default Best full range designs suited to rock music?
Can anyone offer suggestions on full range speaker designs that will do rock music well?
I think my FE206E's in the FE208E sigma cabinet are doing a pretty damn good job of it. Although if there are any other full range speaker designs that will do substantially better with rock, i might like to try!
And as a side question, are there any full range designs that will do rock music well in a small room? I am compromised by room size, but I believe speakers have to be big in order to make music the most enjoyable. I'm worried that if I build smaller speakers in order to suit my room size, I would be unhappy. Although I would be happy for someone to convince me otherwise!
Old 30th November 2007, 09:41 AM   #2
blumenco is offline blumenco  United States
Default pioneer 8incher...
this thing, with some good pentode power, and a decent tweeter is my personal ticket for in home rock concerts IMO. not necessarily the volume, but the presentation. very easy on the ears.
I also like the 206E for rock. it is a surprisingly chill sound, well broken in.
Clark
www.blumensteinaudio.com
Blumenstein Audio - Handmade High Efficiency Full Range Single Driver Speakers from Seattle, USA Since 2006
Old 30th November 2007, 11:46 PM   #3
MPM is offline MPM  United States
Possibly consider a sub to aleviate the main speaker from doing all the work. I'm going to use a Kiega 2.1 amp from madisound for my new computer speaker system that will double as my primary listening system in my office. Not ideal but will work pretty well and free up some space. Haven't made up my mind about my primary speaker but my sub is a Tuba 18 from billfitzmaurice.com. Great sounding and very efficient.
http://www.madisound.com/kgamps.html
Old 1st December 2007, 03:37 AM   #4
sfreak is offline sfreak  Australia
sfreak's Avatar
Also, depends on how low and loud you want them really. I listen to my fair share of rock and metal, and using CSS FR125S', in a 7L vented box. Room size is 3.5m x 3.5m, just hooked up to my Yamaha amp and connected to my PC.
Could always also try planet 10s miniOnken boxes as well. Heard nothing but good from people who have given them a try.
Dan
Old 1st December 2007, 02:06 PM   #5
Timn8ter is offline Timn8ter  United States
Timn8ter's Avatar
I tested a pair of EnABLed Planet10 Fonkens in my home crossed to a 10" sealed sub. They handled everything I fed to them, including Alice In Chains.
Old 1st December 2007, 02:45 PM   #6
bigwill is offline bigwill  United Kingdom
How about the "Afterburner" http://www.fortunecity.com/rivendell...terburner.html
Old 1st December 2007, 03:36 PM   #7
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Nothing, bluntly. Unless supported at the extremes, especially the LF to improve transient handling. That's the extreme take of course. They can do better than a lot of mediocre multiways if loaded right though, and when you get some decent subs & supertweeters on them (or use them above their mass-corner & a dedicated bass-section below) things just get better. It isn't really until you're in the realms of proper HE setups with dedicated multiple woofers per channel & compression drivers above (preferably horn-loaded) that you're likely to get much better.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 1st December 2007, 09:49 PM   #8
Thanks everyone for the advice.
The fonkens crossed to a sub idea sounds great, i will give it some thought.
Scottmoose, when you say "or use them above their mass-corner & a dedicated bass-section below", could you please explain what this means?
Old 1st December 2007, 09:50 PM   #9
Brett is offline Brett
Brett's Avatar
Default Re: Best full range designs suited to rock music?
I work on the principle that if it sounds good loud, it will sound better lower. My personal experince backs this. So I design big and never run out of headroom or have it constipated sounding.
What about adapting or indded using one of the Dick Olher designs?
Agreed.
Old 1st December 2007, 10:21 PM   #10
Scottmoose's Avatar
You could do a whole lot worse.
The mass-corner of a driver is defined by Qt and Fs, and is the point at which the driver's LF response starts to roll off. Assuming for sake of example that we hold Fs constant, then the higher the Q, the lower the mass-corner frequency (i.e. it will start to roll off at a lower frequency, because the driver isn't as well damped). As you'll have figured out from that, it's generally (although not invariably) the frequencies below this point that we tend to use cabinets to boost. Alternatively, you can either mildly boost it, or not bother at all, let it roll off, & use dedicated woofers below this point. The Fonkens with LF support would fall under the popular & generally very effective 'mildly extend / boost the bass below the mass-corner & then support below this point with bass drivers' catagory.
Hope that helps
Scott
Best full range designs suited to rock music?Hide this!Advertise here!
rock music and SE? jarthel Tubes / Valves 16 25th June 2007 11:20 PM
Full Range Dipole Designs - Any Advice? Forster Full Range 5 9th January 2007 01:13 PM
Rock with a full range speaker type Full Range 20 1st July 2006 04:48 AM
Designs with a full range and bass driver? swin1 Multi-Way 3 19th May 2006 10:58 PM
Any 2 or 3 way designs that sound like a full range regal Multi-Way 1 12th August 2005 10:30 PM
Copyright ©1999-2017 diyAudio
