Old 28th November 2007, 07:44 PM   #1
Tomac is offline Tomac  Croatia
Default Paudio coaxial: BIB or Sachiko?
Browsing through plans Scottmoose and Dave recently published it occured to me that this coaxial could work both in Sachiko and BIB. I tried simulating BIB, but don't have any knowledge how to do the Sachiko simulation for that driver. Also I'm pretty unsure what would be optimum length of BIB for that driver.
Any ideas?
Thanks in advance
Old 28th November 2007, 07:54 PM   #2
Scottmoose's Avatar
WRT a BIB, you could try this using the regular calculations.
67.5in tall, 10.25in wide, 14.5in deep, Zdriver 29.5in. I've tuned it to 50Hz. Don't try going below this though.
Old 28th November 2007, 10:01 PM   #3
Godzilla's Avatar
How much are those coax drivers? I've never seen them before. Interesting how they chose the tweeters they did to match up with those woofers. I wonder how they sound? Lately i've been wanting to try pro drivers.
Old 29th November 2007, 12:18 AM   #4
GM is offline GM  United States
GM's Avatar
What about just using the 'stock' BIB height (~48.78 Hz), driver location except on its side due to its depth? This would raise the driver a little and reduce wide/depth to ~10.18"/14.4".
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 29th November 2007, 03:08 AM   #5
Brett's Avatar
Dunno in the US, but I paid $A120/ea on closeout. They're actually quite good sounding based upon my limited testing with a far from optimum xover. The HF drivers apparently have Al diaphrams. I think they have potential.
Old 29th November 2007, 10:11 AM   #6
Scottmoose's Avatar
Originally posted by GM
What about just using the 'stock' BIB height (~48.78 Hz), driver location except on its side due to its depth? This would raise the driver a little and reduce wide/depth to ~10.18"/14.4".GM
Looks good to me.
Sachiko drvomir Full Range 14 26th August 2011 07:00 PM
PAudio Drivers ilewis33 Full Range 17 25th June 2008 10:43 PM
PAudio Coax on an OB abmoggy Multi-Way 7 30th March 2007 07:04 AM
PAudio LF driver, any thoughts? one1speed Multi-Way 7 26th February 2005 05:33 PM
PAudio DIY speakers chanmw Multi-Way 2 7th January 2002 03:21 AM
Page generated in 0.07860 seconds (75.68% PHP - 24.32% MySQL) with 10 queries
