Vas and TQWT
Hello,
This is my first post on this forum !
I want to build a TQWT using Fostex 167e (I already have one with 103e, that is really musical but a bit on the light side).
I prefer when my speakers are not to big (so does my wife):D
Does anyone has an idea concerning the relationship between global volume of a TQWT and VAS (Vas of Fe167e is 35,94L)? should it be under or above it ? what influence on speaker behavior ?
Thanks in advance,
Eric (France)
That's because there isn't really a simple solution unfortunately.
If you make the cabinet too small, then the LF will roll-off due to the lack of sufficient Vb.
If you want a relatively compact cabinet, I'm not sure why you want a TQWT? A simple, untapered MLTL will tend to give better results for a less complicated build. Like the attached plans for the FE167E MLTLs that I happen to be listening to at the moment actually. And no -it's not a BR cabinet. ;)
Well, yes, and no, or I would still be fumbling around trying to find a "simple" math solution to calcing BIBs. Messrs Thiele and Small did all the hard math parts though and Messrs Margolis and Small simplified it even further to Vb = 20*Vas*Qts^3.3, so for the BIB all I did was adjust the exponent based on another fact that I can't explain any more than how they arrived at the constant '20', which is that if you leave the exponent the same and multiply Vas in ft^3 times the ~28.217 liter conversion factor you get a Vb that works quite well for any combination I've ever tried. Since the BIBs tend to be too large for most folks, I went back and shorted it a bit figuring they wouldn't be stuffed nearly as much as a typical TL.
Anyway, using the BIB's Vb = 20*Vas*Qts^1.25 will get you one that once stuffed may sound a bit 'thin' without plenty of BSC and Vb = 20*Vas*Qts^1.1707 a bit more tonally balanced for a given stuffing density and get rid of the exponent altogether for a nice 'phat' ;) sounding pipe that may not require any BSC. Note that I haven't compared these to MJK's or Rick Shultz's calcs which no doubt are more mathematically correct, so I present these more as a small insight as to how little Vas affects pipe design since you want its Vb to 'swamp' it and for those folks that don't use either of these WSs for whatever reason, but want to dabble in TL design.
GM
