#1 | |
http://fullrangedriver.com/forum/viewtopic.php?id=1959
Since no shelf specs given and assuming it will be against a wall, I chose a low tuned MLTL to try and match up to its mids 'hump': L = 21.71" zdriver = 8.58" zport = 18.2" CSA = 38.767"^2 dport = 1.187" Lport = 0.75" All dims i.d. and approximate. Enlarge vent for more mid-bass/higher Fb. Stuff to suit, 0.3 lbs/ft^3 of polyfil shown: GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#2 |
Hi GM,
A cute mltl p.s. - I might finish an iBIBk build before Christmas... regards, fred |
#3 |
Neat.
#4 |
Thanks! If you build, please post stuffing, vent size, etc. used, performance opinions.
#5 | |
how can i design a baffle that would definitely give bigger sound from this small driver without compromise. thank you very much. |
#6 |
I don't do drawings, but it looks like this one except the dims are different: http://www.quarter-wave.com/Project0..._Enclosure.pdf
H = 21.71" W = 7.38" D = 5.25" driver down 8.58" vent cutout up 3.5" The vent is a 1.1875" diameter hole in a 0.75" thick baffle. Not sure what you mean about the baffle design, but the bigger it is the better it will perform down low, so you can make the baffle as big as you have room for. GM
#7 |
thanks for your reply. though this thread is kinda old.
i'll do it. |
#8 |
You're welcome! Please let us know how it performs and any changes and/or fine tuning you do.
GM
| Bookshelf speaker mod | lontas | Multi-Way | 9 | 21st June 2008 05:32 PM |
| Ribbon Bookshelf Speaker | LineArray | Multi-Way | 2 | 6th June 2008 11:38 AM |
| 2-way bookshelf speaker | XizzeriA | Multi-Way | 3 | 9th July 2005 12:53 AM |
| Bookshelf Speaker Reccomendation | gmilitano | Multi-Way | 18 | 24th April 2004 11:06 PM |
| Bookshelf speaker recommendation | RKH | Multi-Way | 33 | 11th October 2003 03:50 PM |
| Page generated in 0.15469 seconds (46.42% PHP - 53.58% MySQL) with 11 queries |
