new fullrange driver from emspeaker
Old 25th November 2007, 08:49 PM   #1
lrntglls is offline lrntglls  Canada
Default new fullrange driver from emspeaker
Michel Fertin, the former owner of Fertin Audio, known for
its field coil line of driver has introduced a new
12 inch (30cm) - high efficiency (98db) -16 ohm -
fullrange (40hz-15khz) driver.
Match a light cone (34gr) with a strong field coil motor and
you get a very dynamic sound.
A whizzer cone keeps the coherence in the sound:
Michel Fertin prefer a gradual cone break up to do the hf than
the adding a tweeter with all the problems it implies.
He has design an open- baffle and a cabinet plan for the
diy.
http://www.emspeaker.fr/
Old 25th November 2007, 09:39 PM   #2
alain_online is offline alain_online  Switzerland
Default Nice nice nice !
Salut Gilles,
How do these compare to 20EX ?
"Just" better bass ?
Alain
Old 25th November 2007, 11:43 PM   #3
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I thought it was a creation from the hands of his daughter, or at least I liked the idea as much as I like the look of that driver, it doesnt seem to produce much bass energy
Old 26th November 2007, 02:57 AM   #4
BHTX is offline BHTX  United States
BHTX's Avatar
34 Hz Fs with a low Qts of .21 with only 1.5mm Xmax? No wonder.
Of course, if it weren't for this, efficiency probably wouldn't be so high.
Old 26th November 2007, 04:51 AM   #5
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Sounds like horn.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th November 2007, 05:21 AM   #6
BHTX's Avatar
Originally posted by planet10
Sounds like horn.
Yep.
Old 26th November 2007, 08:39 AM   #7
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Indeed.
Here's an interesting question though... why do so many websites, for the 'English' language option, use the US flag as the icon?
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 26th November 2007, 11:55 AM   #8
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Yeah, really..............
</OT>
even if 75% of my posts are certainly and deliberately OT , I can't agree more .......... this post of yours can't be more OT than it is .........
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 26th November 2007, 05:12 PM   #9
Hi, as for the bass; the LB12ex has a variable voltage so
the Qts can be increased by lowering the voltage; on the other
hand you loose a bit in efficiency. The Fertin 20ex has a Qts
of .45 and I would not consider it has being soft bass , quite
the opposite. I listen at 10V so the Qts would be near .4,
acceptable I think.
There's always the option of building a cabinet; but open-baffle
sound is the only option for me.
Field coil (strong motor)+ high efficiency+ light cone; these
are the characteristics of the Fertin sound.
Everything is a compromise; the main thing is to get a great
midrange and compromise with the lf and hf. No fullrange
does everything 100% right but it's the overall sound that
is important: fast- detail- alive and with great tonality.
Old 27th November 2007, 08:10 AM   #10
frugal-phile(tm)
planet10's Avatar
Subthread on Cultural Diversity split off to here
http://www.diyaudio.com/forums/showt...hreadid=112644
dave
new fullrange driver from emspeakerHide this!Advertise here!
FullRange driver and bafflestep? Twisted85 Full Range 5 27th May 2009 03:27 PM
3in/8cm fullrange driver test v-bro Full Range 76 18th September 2008 10:13 PM
Elac's new fullrange driver.. ScottG Full Range 0 29th August 2007 11:36 PM
Unknown fullrange driver bigwill Full Range 3 15th February 2005 05:30 PM
DIY fullrange driver? Nappylady Full Range 24 25th February 2004 02:17 PM
Copyright ©1999-2017 diyAudio
