Old 18th November 2007, 01:54 PM   #1
Default BIB with FF225K+FT17H
Hello,
finally they replaced the faulty FF225K with new one.
I had to do some modification to reduce the vibration. I discovered that the wood I used is so weak that the FE206E previously installed was vibrating itself.
Old 18th November 2007, 08:03 PM   #2
Well, after some time of listening.
Huge soundstage
Highs and medium not hard as the FE206E
A lot of bass, lot more than FE206E
If you turn the volume more than normal volume with some heavy bass cd( there aren't many) you hear distortion. I minimized distortion with the position of the speaker, more angle, so you're little bit out of axes.
I'm using it with 1,5 cap. But you cannot cross by ear with this combination of drivers. Infact I'm designing a crossover.Without a crossover the frequency response is not linear. I hope that I don't loose to much soundstage with a more flat response.
With second order crossover
This one is a 1st order
I will try first the 1st order crossover, because it less expensive.
Old 18th November 2007, 09:25 PM   #3
Scottmoose's Avatar
Personally I wouldn't try crossing over until at least 4Khz. Keep it out of the telephone band. The 225 is fine across this region.
Old 19th November 2007, 12:49 AM   #4
badman is offline badman  United States
Custom Title
badman's Avatar
Default Nice to see this driver getting used
Lot of people ignore it, seemingly based upon the xmax spec. Great driver
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 19th November 2007, 07:29 AM   #5
I want to cross it at 6400, to have a flat response
At least it has to be crossed over 5000hz(raccomended by fostex), otherwise I risk to burn it and there's to much distortion.
Do you think liming the angle of the panel where the driver's are mounted will decrease the diffaction?
FLH with FF225K, anyone? CLS Full Range 6 9th June 2009 04:23 AM
FF225K+FT17H in BIB testarossa2k Full Range 36 19th September 2007 10:46 PM
cap for ff225k and ft17h testarossa2k Full Range 2 29th August 2007 09:44 PM
Fostex FF225K PTSOUNDLAB Multi-Way 23 21st July 2002 06:18 PM
Page generated in 0.08361 seconds (73.61% PHP - 26.39% MySQL) with 10 queries
